New Konica I series that will not connect to marketplace.
  • pickle8486
    • Aug 2013
    • 26
    Ok, I'm coming here as I am now having to fire the parts cannon.
    New c250i that will not connect to market place. I completely reset the machine back to zero with the reset tool, reset network, formatted ssd, created new pki cert. I can ping Google and can get to the marketplace via web browser, but cannot get there via the app. I'm lost on this one, even played with the API settings and doing a on/off. Pic include to show what I'm getting.
    Ideas??????
    Sent from my SM-N986U using Tapatalk
  • kingarthur
    • 1399
    Re: New Konica I series that will not connect to marketplace.
    Have you created an account on Market place and have you installed Market place installer on your PC, these both have to be done, you use your Market place credentials to log onto the installer, then use the machines IP via Market place installer to connect to Market place
    • pickle8486
      • Aug 2013
      • 26
      I have an account but this message is popping up before I am even prompted to input the credentials. I am solely doing this from the printer side. I've done a couple others and it went fine, this is the last one and of course has to be a pain in the ass.
      • emujo2
        • Mar 2017
        • 1579
        Marketplace will not respond if the system board has been replaced until you update LMS with the new MAC address. If you have changed ANY boards, or done a factory reset the S/N may also be reporting wrong. Other than that, if you open the web browser and can get to google (for example) then nothing is being blocked. E
        • tsbservice
          Field tech
          • 8081
          Check soft switch 172.
          • Ziggy
            • Feb 2018
            • 815
            Ideas??????
            Not sure why you want market place. we disable this feature on our machines because of all the trouble they cause
            • Synthohol
              Certified Konica Expert
              • 5922
              do a network init.
              • pickle8486
                • Aug 2013
                • 26
                So a little more detail
                Sw 25 is 30
                172 is 5
                I almost always cut marketplace off but this one customer has an app they purchased.
                E, how do I check or resync the lms? This is new info. I did do a reset but only after I couldn't access marketplace. Obviously I tried a network reset, but I have found a compete reset with the tar file fixes almost all issues....... except this one.
                • emujo2
                  • Mar 2017
                  • 1579
                  You would reach out to SSD and open a ticket..again this is only if you are certain that the MAC or S/N may have been altered. E
                  • tsbservice
                    Field tech
                    • 8081
                    Try Initialize all.
