Konica Cxx4e Series Jams 11-01 and 11-02 (Tray 1)
  • fadsamniote
    • Apr 2016
    • 80
  • copyman
    Owner / Technician
    • Sep 2005
    • 4736
    Re: Konica Cxx4e Series Jams 11-01 and 11-02 (Tray 1)
    You should scuff up shafts where the one way clutches contact shaft. Use scotch brite pad or fine sandpaper
    • Ziggy
      • Feb 2018
      • 789
      The registration bushings can get gummy and cause jamming out of tray 1. If you have to go back turn registration rollers by hand and see if it is hard to turn. If it is you will have to pull registration unit and clean the bushings
