Seeking Bizhub c454e firmware
  • frood
    • Sep 2022
    • 18
    I have a BizHub c545e and the firmware is older. I hear that the SLEEP and POWER settings on the most recent firmware sometimes behave better, so I'd like to upgrade.
    If anyone has updated firmware and could send to me, would greatly appreciate it.
    Here's the report of the current firmware on the system page:
    ROM Version
    MFP Card Version A5C10Y0-F000-GDL-M1(00)
    MFP Controller BOOT Program A5C10Y0-1E00-G00-04(00)
    MFP Controller Linux Base Linux-2.6.26.8-rt16
    MFP Controller Kernel Program A5C10Y0-1C00-GC4-76
    MFP Controller SubSet A5C10Y0-1F00-GGV-M1(00)
    MFP Controller A5C10Y0-0100-GDL-M1(00)
    Operation Panel Message Data A5C10Y0-8100-GCJ-M1
    Fax Board Controller1 A22M0Y0-4000-GD0-12(00)
    Fax Board Controller2
    Engine Parameter A5C00Y0-0054-G00-00
    Engine BOOT A5C00Y0-0055-G00-00
    Scanner A5C10Y0-0023-G00-33
    Printer A5C00Y0-0050-GC2-31
    ADF A3CE0Y0-0024-G00-16
    Finisher A3EP0Y0-0071-G10-05
    RU
    ZU
    Panel CPU A55V0Y0-8900-G60-00
    DSC1
    DSC2
    Loadable Device Driver1 A5C10Y0-A001-G00-01
    Loadable Device Driver2
    SD A3ER0Y0-0071-G00-08
    Voice Data
    Movie Data A5C10Y0-C000-G00-30
    Dictionary Data
    OCR Library
    Panel Sound Data A5C10Y0-C200-G00-00
    MFP Controller Thread Image Parameter A5C10Y0-8B00-G00-01
    MFP Controller PIC Image Parameter A5C10Y0-8A00-GC0-06
    MFP Controller System A5C10Y0-1000-GDL-M1(00)
    MFP Controller Print Controller A5C10Y0-3000-GD8-44
    MFP Controller Print Controller Font A5C10Y0-3F00-GCF-40
    MFP Controller Print Controller Demo Page A5C10Y0-3E00-G00-81
    MFP Controller MIO A5C10Y0-5000-G20-W8(00)
    MFP Controller PIC A5C10Y0-8200-GD6-B2
  • Synthohol
    Certified Konica Expert
    • 5907
    Re: Seeking Bizhub c454e firmware
    just enable the ability to disable sleep in service mode and turn it off in admin mode.
    firmware wont make any difference really.
    • frood
      • Sep 2022
      • 18
      Thanks for that, but I want to keep it in 1W power consumption when idle due to need to minimize power footprint of the machine.
      Is there a file repository for the firmware? I hate to bother people about firmware that I could just get myself, but I don't seem to be able to find it online.
      Much obliged for any assistance.
      • Synthohol
        • 5907
        like i suggested, disable sleep totally as it fucks up religiously on konicas. and extend the power save to the max 60m or 240 if there is a bit sw for it.
        scan these forums, sleep mode and the 4,8 and i series seems to kill networking all the time. just disable sleep.
        that series is like 10 years old and barely keeps up with todays security standards. what used to be 5v is now 3.3v in the i series IIRC so if its energy savings you want, there is your answer.
        • frood
          • Sep 2022
          • 18
          Oh, I fully acknowledge that there are sleep issues with the series. I've read that all over the forums, where individuals indicated that the newest firmware helped ... and others reporting no improvement. Thus, I'd figure why not give it a go and see what happens if I could get updates. Sleep/low power works for weeks ... or maybe a few days. Then once in a while, it won't wake up at all. Touch the pad, press the button, no response - you need to hard switch power toggle it to wake it up.
          As far as security, it doesn't really matter - this machine is isolated on its own subnet in a small office and could be swiss cheese and it's not a big deal since only pre-authorized IP addresses can access it. And they're not going to buy anything newer since they're a small nonprofit and it's MOSTLY used as a glorified office printer.
          Thanks! I'll keep digging around.
          • Synthohol
            • 5907
            i lost my KM access after being on disability for 8 months. unfortunately i cannot supply newest FW anymore or i would.
            • frood
              • Sep 2022
              • 18
              I'm sorry to hear about that, Synthohol.
              Wellp, I figured I'd contribute to see if someone else who might have a copy of any modern firmware like GDT-M1 is more likely to lend a hand.
              Great machine, just want to make sure she lives as long as she can.
              • tsbservice
                Field tech
                • 8064
                GDU-M1 latest here was sent. Check your PM.
                Long live the Synthohol!
                We all wish you speedy recovery and best of luck 🤞
                • frood
                  • Sep 2022
                  • 18
                  Revisiting this as I am preparing to do this upgrade finally. (There were a lot of back to back important runs I needed the machine available for, so couldn't risk an issue.)
                  A)
                  I have read a few people who ran into issues upgrading the firmware on the c454e that temporarily bricked the machine. I would like to not brick the machine. I'm going from the GDL-M1 to the GDU-M1 which appears to be nine versions newer. Should I be "stepping" this machine through all the others?
                  Am I overthinking this? (very possible...)
                  B)
                  I can't find how to perform the firmware update in the KM manual except to "upload via the web interface." This is fine, but I found TONS of other locations which show upgrades for KM machines just use a FAT32 4-8GB USB stick in the Service Port with the FW extracted to the root of the USB stick (as files/folders.)
                  C)
                  On the c454e ... where is the USB service port for a FW update? I'm presuming its the one covered by the black plastic cover with one screw to remove.
                  Help appreciated. Figured I'd put it on this same thread since it would then be a "whole procedure."
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4785
                    A)
                    B)
                    C)
                    Service port is not behind black plastic cover! Correct port is behind plain metal plate with one screw, remove screw and plate slides up to insert USB stick.
                    It's hit or miss when loading the most recent F/W in these older models. You can always roll back to earlier F/W if an issue. I've never bricked a "4" series because of loading F/W.
                    FYI, I serviced over 100 of the "4" series when they were current models and disabled sleep mode on every machine. It is still saving power in the low power mode. If you don't mind going out to customer every few months when it won't come out of the sleep mode then leave it on. New firmware will NOT correct this waking up issue!
                    • bowser222
                      • Sep 2020
                      • 6
                      I also agree with sleep mode being turned off.
                      How much energy does the customer save when YOU are paying for gas to drive there.
                      solve the problem as power save works well.
                      gdu-m1 is the latest
                      good luck
