Re: Seeking Bizhub c454e firmware
I also agree with sleep mode being turned off.
How much energy does the customer save when YOU are paying for gas to drive there.
solve the problem as power save works well.
gdu-m1 is the latest
good luck
Revisiting this as I am preparing to do this upgrade finally. (There were a lot of back to back important runs I needed the machine available for, so couldn't risk an issue.)
A)
I have read a few people who ran into issues upgrading the firmware on the c454e that temporarily bricked the machine. I would like to not brick the machine. I'm going from the GDL-M1 to the GDU-M1 which appears to be nine versions newer. Should I be "stepping" this machine through all the others?
Am I overthinking this? (very possible...)
B)
I can't find how to perform the firmware update in the KM manual except to "upload via the web interface." This is fine, but I found TONS of other locations which show upgrades for KM machines just use a FAT32 4-8GB USB stick in the Service Port with the FW extracted to the root of the USB stick (as files/folders.)
C)
On the c454e ... where is the USB service port for a FW update? I'm presuming its the one covered by the black plastic cover with one screw to remove.
Help appreciated. Figured I'd put it on this same thread since it would then be a "whole procedure."
It's hit or miss when loading the most recent F/W in these older models. You can always roll back to earlier F/W if an issue. I've never bricked a "4" series because of loading F/W.
FYI, I serviced over 100 of the "4" series when they were current models and disabled sleep mode on every machine. It is still saving power in the low power mode. If you don't mind going out to customer every few months when it won't come out of the sleep mode then leave it on. New firmware will NOT correct this waking up issue!Leave a comment:
A)
B)
C)
Help appreciated. Figured I'd put it on this same thread since it would then be a "whole procedure."Leave a comment:
GDU-M1 latest here was sent. Check your PM.
Long live the Synthohol!
We all wish you speedy recovery and best of luck 🤞Leave a comment:
I'm sorry to hear about that, Synthohol.
Wellp, I figured I'd contribute to see if someone else who might have a copy of any modern firmware like GDT-M1 is more likely to lend a hand.
Great machine, just want to make sure she lives as long as she can.Leave a comment:
i lost my KM access after being on disability for 8 months. unfortunately i cannot supply newest FW anymore or i would.Leave a comment:
like i suggested, disable sleep totally as it fucks up religiously on konicas. and extend the power save to the max 60m or 240 if there is a bit sw for it.
scan these forums, sleep mode and the 4,8 and i series seems to kill networking all the time. just disable sleep.
that series is like 10 years old and barely keeps up with todays security standards. what used to be 5v is now 3.3v in the i series IIRC so if its energy savings you want, there is your answer.
As far as security, it doesn't really matter - this machine is isolated on its own subnet in a small office and could be swiss cheese and it's not a big deal since only pre-authorized IP addresses can access it. And they're not going to buy anything newer since they're a small nonprofit and it's MOSTLY used as a glorified office printer.
Thanks! I'll keep digging around.Leave a comment:
that series is like 10 years old and barely keeps up with todays security standards. what used to be 5v is now 3.3v in the i series IIRC so if its energy savings you want, there is your answer.Leave a comment:
Is there a file repository for the firmware? I hate to bother people about firmware that I could just get myself, but I don't seem to be able to find it online.
Much obliged for any assistance.Leave a comment:
just enable the ability to disable sleep in service mode and turn it off in admin mode.
firmware wont make any difference really.Leave a comment:
I have a BizHub c545e and the firmware is older. I hear that the SLEEP and POWER settings on the most recent firmware sometimes behave better, so I'd like to upgrade.
If anyone has updated firmware and could send to me, would greatly appreciate it.
Here's the report of the current firmware on the system page:
ROM Version
MFP Card Version A5C10Y0-F000-GDL-M1(00) MFP Controller BOOT Program A5C10Y0-1E00-G00-04(00) MFP Controller Linux Base Linux-2.6.26.8-rt16 MFP Controller Kernel Program A5C10Y0-1C00-GC4-76 MFP Controller SubSet A5C10Y0-1F00-GGV-M1(00) MFP Controller A5C10Y0-0100-GDL-M1(00) Operation Panel Message Data A5C10Y0-8100-GCJ-M1 Fax Board Controller1 A22M0Y0-4000-GD0-12(00) Fax Board Controller2 Engine Parameter A5C00Y0-0054-G00-00 Engine BOOT A5C00Y0-0055-G00-00 Scanner A5C10Y0-0023-G00-33 Printer A5C00Y0-0050-GC2-31 ADF A3CE0Y0-0024-G00-16 Finisher A3EP0Y0-0071-G10-05 RU ZU Panel CPU A55V0Y0-8900-G60-00 DSC1 DSC2 Loadable Device Driver1 A5C10Y0-A001-G00-01 Loadable Device Driver2 SD A3ER0Y0-0071-G00-08 Voice Data Movie Data A5C10Y0-C000-G00-30 Dictionary Data OCR Library Panel Sound Data A5C10Y0-C200-G00-00 MFP Controller Thread Image Parameter A5C10Y0-8B00-G00-01 MFP Controller PIC Image Parameter A5C10Y0-8A00-GC0-06 MFP Controller System A5C10Y0-1000-GDL-M1(00) MFP Controller Print Controller A5C10Y0-3000-GD8-44 MFP Controller Print Controller Font A5C10Y0-3F00-GCF-40 MFP Controller Print Controller Demo Page A5C10Y0-3E00-G00-81 MFP Controller MIO A5C10Y0-5000-G20-W8(00) MFP Controller PIC A5C10Y0-8200-GD6-B2
