c3320 reboots every 30 min like clockwork
  • plus-COPY
    • Aug 2023
    • 26
    Re: c3320 reboots every 30 min like clockwork
    Originally posted by 4Toon
    Just reboots with no message or does it say internal error rebooting?
    We could use more information:
    1. Are the date and time settings up to date after turning the power cord off and on again?
    2. How does Administrator mode work?
    3. What errors are in the List Output ?
    4. Is it still possible to update the firmware ?
    I wish you successes
    • barber782
      • Aug 2011
      • 284
      Had 6 of these do the same thing, all on latest FW etc. Did the self diagnostics with no errors, did CPU reset.
      After a month of scratching heads we found out (from the customers IT department who were monitoring every time it restarts) that it was caused by the NTP settings.
      Under > maintenance >date and time >time server/timer adjustment: input '1.pool.ntp.org'
      Also had this happen on 8 C550i's. fixed all of them even though we changed boards and all sorts.
      Really weird one.
      • tsbservice
        Field tech
        • 8003
        Originally posted by barber782
        Really weird one.
        Thanks for heads up really strange never heard that. Yet another proof this forum is invaluable resource and better than any manufacturer's tech support.
        • Hap
          • Jan 2017
          • 33
          #19
          Really weird one.
          not sure what i am supposed to do here ,input what u typed into there?
          • Synthohol
            Certified Konica Expert
            • Mar 2016
            • 5814
            #20
            you can just disable NTP and set the time and date manually if it needs adjusting.
            • barber782
              • Aug 2011
              • 284
              #21
              time.windows.com
              • Woxner
                • Jul 2011
                • 845
                #22
                Q6 has a known problem for this. Thas ts why it was taken off site. Use P8. Thisd goes for all small machines
                • techsxge
                  • Jan 2022
                  • 660
                  #23
                  Difference is most manufacturer tech support train their people to never say that they had issues with something before. I've worked part time for tech supports and this is what you are being told in the first few days.
                  All Product Problems are a first for support.
                  Here on copytechnet, if we know a machine (series) has fucked up in the past, we say that it fucked up in the past. Even though others hear it for the first time
                  • Hap
                    • Jan 2017
                    • 33
                    #24
                    i tried that time setting didnt help its kinda wierd it happens every half hour at a specific time like 12 min after and again in half hour even happens at that time if the machine has only been on for a few min
                    • barber782
                      • Aug 2011
                      • 284
                      #25
                      Exactly what answer I get from our tech rep. Every time I have a problem with a machine they're like 'oh that's strange, never heard of that before'. Come on copytech and find everyone else is having the same issues.
                      • Hap
                        • Jan 2017
                        • 33
                        #26
                        ok its fixed did an all clear but that didnt work ended up replacing cpub board and all good
