c3320 reboots every 30 min like clockwork
  • Hap
    • Jan 2017
    • 34
    [Misc] c3320 reboots every 30 min like clockwork
    updaated fw to latest ver q6 checked all timer settings and set as per konica ,cust says it reboots even if unplugged from network kinda at a loss ran diagnostic tool with no fault found
  • Synthohol
    Certified Konica Expert
    • 5841
    Re: c3320 reboots every 30 min like clockwork
    is anyone monitoring the voltage at the outlet during these reboots?
    • tsbservice
      Field tech
      • 8020
      Clear all data Done?
      • Ziggy
        • Feb 2018
        • 761
        Is this a C3320i? if so try running firmware Gxx.26 it says its for boot issues but will check boards see attached
        • avecosat
          • Jun 2012
          • 305
          If it's a 3320i I've had a couple of those problems and it was always the CPUB
          • WIWA
            • Mar 2009
            • 97
            Thanks for the good information
            • JasonSBE
              • Apr 2014
              • 186
              I had a c3320i that was doing this recently. Eventually it locked up on the boot up screen. Ended up being a corrupt/bad microSD card. Chicken and the egg, though. Not sure if the rebooting corrupted the card of if a corrupt card was causing the reboots. Good luck. These machines are..... problematic.
              • Hap
                • Jan 2017
                • 34
                i ran this firmware and no faults were found
                • Synthohol
                  • 5841
                  please run full self diagnostics from service mode, maybe it will help narrow down the point of failure?
                  • tsbservice
                    Field tech
                    • 8020
                    Unfortunately self diagnostic or boot issues firmware never worked for me. I series are so simple, you have CPUB and SSDB/flash card. It's one of them 100% depending on symptoms. Some experience, common sense and knowledge how machine functions help as well.
                    • Synthohol
                      • 5841
                      a few of the i series that have crazy weirdness seem to be fixed by a new CPU board or storage board, i totally agree there.
                      i just dont like the shotgun approach and just throw a board on it, i like when something else tells me its likely that part
                      a couple times ive had newer machines do weird stuff and reboot or the panel is locked or some rando fuser code when idle, turns out both times they had a new HVAC unit installed and the draw is more than the previous one and i saw the lights dim slightly and the copier had a conniption fit.
                      thats why i ask to check wall voltage and neutral to ground.
                      with all the new machines using 3.3v and any voltage on the neutral ground can piss off the copier especially during a surge/sag event.
                      • tsbservice
                        Field tech
                        • 8020
                        Hey Synt, quote you was respectful...and unnecessary. 100% you are correct I just skipped zillion of steps done in between before boards. I'm the last one who will throw new parts in machine for troubleshooting problem.
                        • Synthohol
                          • 5841
                          Not one thing i said was directed at anyone at all, just my experiences and work ethic.
                          If it seemed to infer anyone other than myself I assure you it was unintentional.
                          My apologies if that's how it came across.
                          • antone
                            • Oct 2014
                            • 344
                            Replacement CPU
                            Sent from my SM-S918U using Tapatalk
                            • 4Toon
                              • Mar 2023
                              • 112
                              Just reboots with no message or does it say internal error rebooting?
                              Permanently banned from Konica SSD.
