SD-506 Saddle Stitcher Receiver
  • CopyTech03
    • Jul 2020
    • 54
    [Error Code] SD-506 Saddle Stitcher Receiver
    Accurio Press c3080 with SD-506 is giving Replace Saddle Stitcher Receiver message and indication when it was just replaced and counters reset. Anyone have any ideas how to clear the message?
  • zayonc
    • Jan 2022
    • 49
    Re: SD-506 Saddle Stitcher Receiver
    there is a whole procedure for replacing it and installing it in home position. read the manual
    • CopyTech03
      • Jul 2020
      • 54
      I did
      • copytechman
        • Nov 2008
        • 929
        I know this is old but is it called something else in the service manual? I cannot find reference to replacement of the receiver as a part is it the same as the trim receiver board assy ?
        Theres procedures to replace the trim blade. paddle and board assy with a dip sw to reset a solenoid count is this the same thing?
        Any info is appreciated. Thank you.
        A
        • Ziggy
          • Feb 2018
          • 693
          Look under F PERIODICAL MAINTENANCE 28.5.2 Replacing the trimmer board assy in the service nanual
          • copytechman
            • Nov 2008
            • 929
            Thank you found it and understand how the reset works now.
            Much appreciated!
            A.
