press c12000
  • romario
    • Jun 2020
    • 192
    press c12000
    20221111_143919.jpgHello group, has anyone had any problems with the transfer belt module? The image is distorted when transferring to paper... I have already ruled out everything and have come to the conclusion that the transfer module is bent but I don't know if this has happened to anyone
    thanks
  • Synthohol
    Certified Konica Expert
    • 5848
    Re: press c12000
    Looks more like a trapezoid to me.
    Reset and perform the both sides adjustment with a nice clear scale (ruler)
    I saw no sign of physical damage on the pattern.
    Just looks all skewed up
      • 23009
      Re: press c12000
      A simpler (easier to explain) possibility is a paper skew.
      It could be happening from only a single tray, or all the trays. The hard part in diagnosing a paper skew is that it can happen anywhere from pickup to the registration roller (and anything in-between).
      I think I'd start by testing all the trays to determine if it's just one tray or paper size having the issue. To narrow it down, I think I would key the front door, then emergency stop the machine several times to see when the skew is starting. =^..^=
      • wjurls
        • Feb 2017
        • 498
        Re: press c12000
        If either transfer belt unit was bent, you would for sure get belt runoff error codes. This model is notorious for second transfer belt errors as it is.
