bizhub C258 firmware
  • meric69
    • Jun 2023
    • 5
    [Error Code] bizhub C258 firmware
    Good morning,
    I encounter an error code D011 on my C258.
    Could you help me to solve this problem?
    Maybe do a firmware update?
  • avecosat
    • Jun 2012
    • 304
    Re: bizhub C258 firmware
    Search the forum there are several posts talking about this topic
    Here https://www.copytechnet.com/forums/k...011+forum%3A40
    • meric69
      • Jun 2023
      • 5
      Thank you for your reply.
      Can you tell me where I can get firmware ?
      • Synthohol
        Certified Konica Expert
        • Mar 2016
        • 5808
        Happy to supply this firmware fix.
        Printer Firmware Download
        • tsbservice
          Field tech
          • 7989
          Originally posted by Synthohol
          Wise way to deflect malaperts.
          • meric69
            • Jun 2023
            • 5
            Thank you very much I have firmware FW_A7PU0Y0-F000-GCH-X4
            Unfortunately, I can't find the installation procedure.
            Could you please help me
            • Synthohol
              • Mar 2016
              • 5808
              extract it, put only the fw0000xx folder in the root of a 4 gb flash drive.
              plug into front usb power on wth main switch while holding the stop button.
              when a dot appears let go of button and fw will start in a min.
              • meric69
                • Jun 2023
                • 5
                Thank you so much. I also have Movie data A7PU0Y0-C000-G00-90_Movie_F4.2
                Do you recommend me to install it?
                I can not install the firmware by performing the same procedure
                • Synthohol
                  • Mar 2016
                  • 5808
                  movie data is just the single extracted .tar file on the root of the flash drive a and installed in service mode, system 2, 2nd page "install data"
                  put the usb in the front port, wait until 'set' appears hit it and hit start.
                  do you want a service manual? sounds like one would be handy to have.
                  • meric69
                    • Jun 2023
                    • 5
                    After installing the firmware I still have the error code D010.
                    Do you know where the problem comes from?
                    • Synthohol
                      • Mar 2016
                      • 5808
                      check the harddrive in the back is connected properly and is enabled (set) in service mode.
                      look it up in the manual you have.
                      • tsbservice
                        Field tech
                        • 7989
                        It's time to call a tech.
                          • 8132
                          [ATTACH=CONFIG]58512[/ATTACH]
                          [ATTACH=CONFIG]58513[/ATTACH]
                          [ATTACH=CONFIG]58514[/ATTACH]
                          [ATTACH=CONFIG]58515[/ATTACH]
                          You need SATA recovery firmware for the C-D011 error.
                          https://mega.nz/file/NBMWxbCA#3MmHlP...aUD8Eg-R4DuLeo
                          • 4Toon
                            • Mar 2023
                            • 110
                            Please look at bulletin #10072 10/2/16 with procedure on how to prevent/fix this code
                            Permanently banned from Konica SSD.
                            • strider5555
                              • Jun 2008
                              • 96
                              Looks lite the sata firmware is already updated, you can try the recovery firmware GXX-A8, but that code says the HDD is not formatted, so step 1, check all hdd connectors, step 2 in service mode try logical format, if error still occurs, try a new harddrive.
