Print Is Fine But Copy Has A Shadow Background and lines Bizhub C558
  • Ankit777
    • Jan 2021
    • 2
    [CQ] Print Is Fine But Copy Has A Shadow Background and lines Bizhub C558
    My bizhub c558 was working fine untill we shifted the machine to my other office.Print Is great But there is a background or a shadow while copy from glass as well as adf.I tried cleaning the optics but still the same.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4679
    Re: Print Is Fine But Copy Has A Shadow Background and lines Bizhub C558
    The pic is really small so can't see the defects but from what you posted about happening after moving machine only thing that makes sense is it was pushed using the adf and now adf is crooked. Just a guess without seeing the pic.
    If you post a better pic it will be easier to help.
    • Synthohol
      Certified Konica Expert
      • 5822
      is the lighting different at its new location? if it can peek under the ADF there might be the issue.
      also if its slightly skewed you may need to lift the front left corner of the scanner like you are trying to actually lift the machine to straighten the now trapazoided scanner bed.
      make a copy with the lights off to test.
      sometimes its that silly.
      also can test a copy on the glass but keep about 20-30 lbs of pressure upward on the front left corner.
      sometimes when machines are moved someone puts something heavy on top like a bunch of reams of paper and the scanner bed sags.
      all very easy tests.
