BH363, C8101
  • Hansoon
    • Sep 2007
    • 3391
    BH363, C8101
    Manual says: "Before reading pressure welding alienation mechanism trouble"
    Hard to understand what the manual means.
    Is this Japlish or can I not understand because my mother language is not English?
    LOL
    Never had this ADF error code. Any hints what to do please?
    Hans
  • allan
    RTFM!!
    • 5462
    Re: BH363, C8101
    Something to do with that motor.
    Never seen that code...
    Whatever
    • Synthohol
      Certified Konica Expert
      • 5892
      Re: BH363, C8101
      check all connectors, do a sensor check as noted.
      can you spin the motor by hand? maybe its all jammed up with a paper clip that is jamming up a belt.
      take covers off and watch operation as it initializes at boot.
      3.12.1 C8101(1) Contentsbizhub 423/363/283/223 K TROUBLESHOOTING > 3. TROUBLE CODEK-66(2) Procedure
      Step Action Control signal Location of electrical components
      1 Check the connector between M3-relay CN5-DFCB J15 for proper connection and correct as necessary. - -
      2 Check the connector between PS12-DFCB J15 for proper connection and correct as necessary. - -
      3 Check the connector of M3 for proper drive coupling, and correct as necessary. - -
      4 PS12 I/O check, sensor check DFCB J15-3 (ON) DF-621 G-1
      5 M3 operation check DFCB J15-4 to 5 DF-621 G-2
      6 Change M3 - -
      7 DFCB F8 conduction check - -
      8 Change DFCB
      • allan
        RTFM!!
        • 5462
        Re: BH363, C8101
        Think its to be able to remove jams when released.
        open the image it should be good enough to read i hope.
        Whatever
        • allan
          RTFM!!
          • 5462
          Re: BH363, C8101
          Seem like I am wrong. It releases so that the downstream drive is free to transport the paper.
          One tough little DC motor.
          Does a similar job to the solenoid on the exit roller pair.
          DF-612 is probably the best and most reliable DFs KM has made.
          Whatever
            • 23010
            Re: BH363, C8101
            Were I to guess, I would say that the function of this mechanism is to take the pressure off of those rollers while the trailing edge of the original is passing. On some DF's you can get an image shift (front to back) towards the trail edge of the original, just at the moment the original clears the last set of rollers.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4765
              Re: BH363, C8101
              It may have been one of the best ADF's but also one of the loudest! The white sheet coming off bottom of ADF was perhaps the most common issue.
              • Hansoon
                • Sep 2007
                • 3391
                • femaster
                  • May 2011
                  • 1519
                  Re: BH363, C8101
                  I've only ever heard that error description in relation to the transfer belt, for the color roller retraction mechanism. I suppose the ADF rollers also retract so it sort of makes sense. The description really isn't very good though, as I don't see how that combination of words could be associated with the physical action of retracting or applying a set of rollers.
                  • allan
                    RTFM!!
                    • 5462
                    Re: BH363, C8101
                    Originally posted by Hansoon
                    Thanks all of you guys.
                    Still, I find “pressure welding alienation” a very creative expression. LOL
                    Hans
                    Yea it made me curious.
                    What was wrong with it? Then again there are so many DF-621's around it would be easier just to change it.
                    Whatever
                    • Hansoon
                      • Sep 2007
                      • 3391
                      Re: BH363, C8101
                      Just came from the customer, didn't see the machine myself before. I noticed that the optical sensors were extremely dusty. They use the machine mainly as a scanner. Though I did not see any relation, I cleaned those, of course and made a hard error reset and everything was well.
                      Thanks gentlemen
                      Hans
                      • copyman
                        Owner / Technician
                        • Sep 2005
                        • 4765
                        Re: BH363, C8101
                        Thanks gentlemen
                        Hans
                        Thanks for the follow up. Usually weird codes like that reset and you never see them again....
                        • Hansoon
                          • Sep 2007
                          • 3391
                          Re: BH363, C8101
                          "Weird" indeed because when the machine came back to life after the error reset it showed in the beginning for a short moment Japanese characters in the display.
                          Hans
                          • tsbservice
                            Field tech
                            • 8053
                            Re: BH363, C8101
                            Someone was lost in translation from Japanese to English for sure. Plus there are some inherited codes from older engines I think. That's where service engineer takes place and should do some magic like Hans did
                            Btw Hans your back is seriously covered by most of experienced techs coming frequently here, you owe a considerable amount of good German beer to lot of folks
                            Have a very nice day/evening all!
                              • 23010
                              Re: BH363, C8101
                              Thanks for posting back. A dirty position detection sensor makes a lot of sense, especially on a machine this old. =^..^=
