C454E blue on edges and faded prints
  • positiveg
    • Jun 2018
    • 299
    Please take a look at this.
    The cmy developers are over 80% with the black at 54%
    The drums are all over 90% but the cyan at 24
    This was not happening before I juat topped up the cyan developer so that could be the cause of the cyan on the far edge of the paper. However the faded colours in the middle those were not happening before I think.
    Hope to get some help please thanks
    Sent from my SM-G780G using Tapatalk
  • copyman
    Owner / Technician
    • Sep 2005
    • 4651
    Re: C454E blue on edges and faded prints
    Yes that is most likely from the developer you added. I would run some cyan half tones in service test mode. keep checking the level history under state confirmation after every few halftone prints. get around 6.5 - 7%. Then do gradation adj.
    Also looks like you have a magenta strip at bottom of page?
    • elmaligno
      Expert technician KM
      • Oct 2009
      • 302
      You should take a look at this
      Field technician since 1994
      • copier tech
        • 8133
        Swap the yellow & cyan drums around does the print quality change ?
        Also you don't 'top up' developer you replace the complete unit.
        • L0rdC
          • Feb 2021
          • 82
          This is happening to me on a C360, the edge of the drum is stained and causes this, check the drum
          • rrrohan
            • Sep 2011
            • 1977
            good advise
            if it doesnt follow drum you can be confident its the dev
            • kingarthur
              • 1338
              It looks like a dirty charge corona on the drum unit, it may not show straight way on the other colour, when you swap the drum.
              • positiveg
                • Jun 2018
                • 299
                I'll give the switch
                • positiveg
                  • Jun 2018
                  • 299
                  Hi all. Ok I change the cyan drum but in a new drum and also change the magenta drum because was getting aomw magenta hues. Had to do a few prints to clear the hue and before the colur started coming back to normal. Also the blue on the edges that too started to be reduced.
                  Thanks so much. I thought it would have been more. But it definitely will need a clean up.
                  Thanka all again
                  • L0rdC
                    • Feb 2021
                    • 82
                    Thanka all again
                    It just happened to me again with a C360, cleaning the drum and crown brush and solved, the question I have is, why does it always happen with the cyan unit?
                    • positiveg
                      • Jun 2018
                      • 299
                      That is a very good question. Because I too have only ever had it with cyan. Like it would just happen.
                      With my c75 certain things too happen with my cyan laser where it tends to get diertier quicker than the other ones.
