450i boots into self-diagnostic
  • OEM1
    • Mar 2015
    • 33
    [Error Code] 450i boots into self-diagnostic
    Desperately need help. Not a Konica tech but have 30+ years in copiers. This machine cycles, optics move & lamp comes on. But, boots into self-diagnostic. If I press start it runs diagnostic & everything says ok. Can't get into service mode. Changed HDD, HDD pwb & main pwb. All with new parts.
  • tsbservice
    Field tech
    • 8031
    Re: 450i boots into self-diagnostic
    To start with bizhub 450i has no HDD but SSD. Run diagnostic tool for bootup issue but if you already tried new SSD and baseboard without success that's CPU board failed.
    • Ziggy
      • Feb 2018
      • 789
      NOTE SW25 should be set to the hex according to which firmware version is on the machine.
      Problem
      When MFP is powered ON it displays service mode/ self diagnostics on the operation panel.
      Solution
      CAUSE: Firmware anomaly
      SOLUTION: Perform the following.
      1. Select Counter
      2. Select Display Keypad
      3. Press Stop 00. Stop 01
      4. If applicable input CE password 9272 4 times (Default)
      5. Select System 2
      6. Select the following Software Switch Settings
      a. Set Switch No. 25 to HEX Assignment to 10
      b. Set Switch No. 163 to HEX Assignment to 02
      7. Press Fix
      8. Press End
      9. Select System 2
      10. Select Internal Error Auto Cancel
      11. Select Rank C and press Yes
      12. Press END
      13.The MFP will automatically reboot by the change of Internal Error Auto Cancel
      • copier tech
        • 8192
        Problem
        Solution
        1. Select Counter
        5. Select System 2
        7. Press Fix
        8. Press End
        9. Select System 2
        12. Press END
        What does SW163 do ?
        Thanks for this info, very helpful.
        • Ziggy
          • Feb 2018
          • 789
          • Ziggy
            • Feb 2018
            • 789
            Attaching manual pages
            • tsbservice
              Field tech
              • 8031
              It's in manual but who is enough wicked to RTFMs.
              Brother Phil here I come. You are completely right it's insane but I've done it 🤣
              I'm guilty, I must read more books again!
              • tech51
                • 846
