Doc feeder J6633
  • kenpio
    • Dec 2015
    • 201
    [Jamming] Doc feeder J6633
    Good morning,
    Have a C450i that is jamming in the doc feeder. It does not even have over 100k on it. I go to the test mode and run the paper passage, put a stack in and press start. It starts pull in paper in and it is going and all of a sudden a KLUNK and a J6633. I have cleaned all the sensors in the path and there is no reason that I can see why it does this. It could be at the beginning of the stack and then I think it s going all the way through and then KLUNK!!! I have tested the sensors and they are good. Just one of those things. Any input would be swell!!!
    KEN
  • 4Toon
    • Mar 2023
    • 112
    Re: Doc feeder J6633
    Can you pull the paper through the DP or does it catch? I would do a sensor check and manual flag sensors and make sure they are all turning on and off. The turn over sensor has had alot of issues for me in the past
    Permanently banned from Konica SSD.
    • allan
      RTFM!!
      • 5462
      Check tension on the belts at the back.
      Whatever
      • kenpio
        • Dec 2015
        • 201
        Yea you can pull the paper through, there are no tick on the paper. I did "adjust" the post that holds the cover down. I have had trouble with those. Yea pretty much the paper is laying in the feed section and then pull the paper out the exit. I will check the belts and sensors.
        THanks
        KEN
        • Synthohol
          Certified Konica Expert
          • 5846
          judging just by the noise you describe it sounds like a wayward paperclip riding on a belt and locks up on a gear.
          thats my guess final answer
          • Woxner
            • Jul 2011
            • 850
            If you dont find a paper clip check the frame for gear drive on top door. There is a bulliten on this.
            • 4Toon
              • Mar 2023
              • 112
              THanks
              KEN
              If the paper makes it all the way around the bend and you pull it out the bottom or the exit like you said I would bring a turn over optical sensor with you when you go.
              • kenpio
                • Dec 2015
                • 201
                Looking on KM and where is this bulletin. I know it is a labyrinth of info. Just a hint please.
