Konica bizhub C3350i IWS has been terminated
  • copyguy69
    • Feb 2016
    • 94
    Customer is getting the following: Error has been detected - IWS has been terminated. Is this a problem with the copier or with the customers network? I am not sure what is causing this error or how to correct it. Any suggestions are welcome. Thanks in advance
    copyguy69
  • Synthohol
    Certified Konica Expert
    • 5847
    Re: Konica bizhub C3350i IWS has been terminated
    if they are not using Marketplace disable IWS under network in admin.
    • emujo2
      • Mar 2017
      • 1579
      Km is striving to have all of their equipment available for remote monitoring and firmware updates..I wonder if someone is trying to do one of these..I remember reading that IWS in involved.
      • tsbservice
        Field tech
        • 8020
        Exactly or just disable Marketplace under IWS settings. Both should get them out of error.
        • Ziggy
          • Feb 2018
          • 770
          If turning off Market Place also go in to service mode and set SW 172 to hex 01.
