c654e does not stop feeding toner, then c2553, TCR reading in 2
  • TEST10
    • Jun 2010
    • 69
    [Dead] c654e does not stop feeding toner, then c2553, TCR reading in 2
    it does not stop feeding toner, since the tcr reading is very low 2
    change
    imaging unit M(x2)
    PRCB
    PHRYB
    The lines of the connector of the unit to the PHRYB give continuity...
    I even put unit C in position M, exchanging the chips... and I have the same result, the TCR reading M 2% (unit C)
    I think the problem is the T/C ratio detection, because this value can be affected?
    Today I will try the initialization clear all data and update the firmware.
    I run out of ideas
  • tsbservice
    Field tech
    • 8014
    Re: c654e does not stop feeding toner, then c2553, TCR reading in 2
    I don't think you put new M IUs, did you?
    • TEST10
      • Jun 2010
      • 69
      no, probe 2, which borrows from equipment currently working, with normal TRC measurements (In fact, I had to cover the toner input because if I didn't recharge them with toner)
      • tsbservice
        Field tech
        • 8014
        Using used IUs(developing units) you need new TCR chip to calibrate machine or it gonna be hit or miss.
        • copier tech
          • 8144
          change
          imaging unit M(x2)
          PRCB
          PHRYB
          I run out of ideas
          Replace the magenta imaging & developer units with new ones.
          You can create more problems swapping used units about.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4700
            At one time was servicing around 50 of the C654 / C754e's and swapped Image units many times from one machine to another without issues. I think you may have something else going on?
