Bizhub 501 Error Code C-D203 Tried Replace CF card, NVRm but No Solving Experts Help
  • manzoorwighio
    • Dec 2019
    • 28
    Bizhub 501 Error Code C-D203 Tried Replace CF card, NVRm but No Solving,
  • Synthohol
    Certified Konica Expert
    • 5823
    Re: Bizhub 501 Error Code C-D203 Tried Replace CF card, NVRm but No Solving Experts H
    code is OACB or PRCB related according to the manual, the CF card nor NVram have nothing to do with that code in the book, just saying.
    says a communication issue between the 2 boards.
    • femaster
      • May 2011
      • 1501
      No need to start a second thread for the same machine and problem. You're only going to confuse yourself and those that are trying to help you out by spreading answers in 2 different places.
      Original post from yesterday:
      Konica Bizhub 501 C-D203 error show
      • Ziggy
        • Feb 2018
        • 724
        C-D203 at power ON.
        Known Error
        Related Products:bizhub 501,bizhub 361,bizhub 421
        Related Options:
        Error
        C-D203 at power ON and the code may not reset.
        Root Cause
        1. The OACB (Overall Control Board) has failed.
        2. A poor connection between the scanner drive motor and PWB-SDB.
        Workaround/Fix
        1. Before replacing the OACB, reseat the and Memory on board connections. If the issue is still unresolved, replace the OACB (p/n A0R5 H010 06).
        2. Reseat CN62 on PWB-SDB. If the problem persists, replace PWB-SDB (p/n 50GA -905 0).
