Bad image c658
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    [Misc] Bad image c658
    Good afternoon colleagues, I have in the same client 5 C-658 which all have the same problem:
    Very often the image becomes poor quality, poor and blurred colors, etc. simply doing the reset and stabilizer is solved in all cases, the consumables are ok.
    The issue is that the user can't be doing it every day from the expert administrator setting, and loses a lot of prints when the problem occurs. The only thing that makes this client different from others is that it does a lot of prints per day.
    I tried to look for an option so that the machine when turning it on in the morning performs the stabilize and reset and not only the stabilize, but I did not see anything.
    Any idea?
    Thanks in advance
    Field technician since 1994
  • barber782
    • Aug 2011
    • 286
    Re: Bad image c658
    Samples?
    Sent from my VTR-L09 using Tapatalk
    • elmaligno
      • Oct 2009
      • 302
      Re: Bad image c658
      Originally posted by barber782
      Samples?
      Images attached before and after reset + stabilizer
      • elmaligno
        • Oct 2009
        • 302
        Re: Bad image c658
        Any idea?
        Thanks in advance
        The issue is that as it is solved by running reset + stabilizer and it happens in the 5 machines, I do not think they have the same failure the 5, then the solution I'm looking for is how to make the machine perform the adjustment automatically.
        • Synthohol
          Certified Konica Expert
          • 5861
          Re: Bad image c658
          reset and stabilize without running all gradations is pointless.
          it cannot do that by itself.
          when you run full gradations then stabilize again (not reset), that reading will stay in memory and the machine will try to keep up with it.
          that should help
          • Ziggy
            • Feb 2018
            • 789
            Re: Bad image c658
            Almost looks like a laser problem. But before we go down that rabbit hole what are the counters of drum , transfer belt and transfer roller?
            • tsbservice
              Field tech
              • 8029
              Re: Bad image c658
              Depending on what they're printing you can tell the machine to prioritize stabilization control on black or color output. Other than that we cannot really influence with stabilization control.
              Keep in mind to clean IDC sensors on any call or PM activities
              • Ziggy
                • Feb 2018
                • 789
                Re: Bad image c658
                that should help
                I didn't notice that he didn't run gradation. I'm in 100% agreement with you
                • elmaligno
                  • Oct 2009
                  • 302
                  Re: Bad image c658
                  They are 5 machines. Consumables OK
                  • Ziggy
                    • Feb 2018
                    • 789
                    Re: Bad image c658
                    Like Synthohol said after you initialize the gradation settings you must run gradation again to give the machine a baseline. you may have to run each gradation several times . the correction level should be between -100 and +100. the closer to zero the better
                    • suomi
                      • Oct 2008
                      • 152
                      Re: Bad image c658
                      System2>image stabilization setting>color priority. maybe make adjustments more often??
                      • Synthohol
                        • 5861
                        Re: Bad image c658
                        without a baseline from proper calibration (cleaning and gradations) any color setting is just willy-nilly.
