Bizhub press1250
  • slytukana
    • Feb 2015
    • 48
    Bizhub press1250
    Hi ,
    I need help on a bizhub press when printing it prints well but comes out with a strange line see the attached on what I mean. The lines are circle in green . The lines are not on the same spot all the time it changes position..
    Appreciate your help in fixing this issue.
    Thankyou
    Sent from my TECNO KG5k using Tapatalk
  • Toxic
    • 698
    Re: Bizhub press1250
    What is drum and cleaning blade counter because it looks like cleaning blade problem?
    • slytukana
      • Feb 2015
      • 48
      Drum and cleaning blade are new
        • 23010
        Those are toner density patches that are written to the drum between pages. They are used for maintaining developer density. The reason that you see then is that the drum is not cleaning properly. =^..^=
        • Ziggy
          • Feb 2018
          • 801
          High probability that the gears on the front of the drive for the cleaning brush on the transfer belt are stripped out. Especially if these are two sided documents
