Konica Minolta C658 Quality issue
  • Kenny
    • Jun 2009
    • 526
    Good Morning,
    Ive got a quality issue with a Konica Minolta C658,
    Ive replaced the cyan drum for blue lines, calibrated the copier cleaned IDC sensors and all the halftones are perfect but when trying to print a document it coming out more green / blue when it should be a solid blue,
    Ive printed the same document on a different C658 from the same Mac & PC and it prints perfectly,
    There is no p codes on the copier and nothing is over life,
    The test page looks perfect too but something is not right,
    I will attached some examples,
    the 2nd example is how it should print,
    Has anyone else had this issue before?
  • tsbservice
    Field tech
    • 8013
    Re: Konica Minolta C658 Quality issue
    Did you put new cyan drum unit?
    • Profibastler
      • Nov 2014
      • 102
      Hi, did you tried change cyan toner.
      Adjust color registration - SM I-103,
      Imaging process adj - SM I-108.
      Mix new toner in dev unit with code 50 - SM I-204
      At last change deve unit.
      Originally posted by Kenny
      Good Morning,
      • Ziggy
        • Feb 2018
        • 732
        What is the count on the rest of the consumables? If they still have a lot of life I recommend the following
        Run Initialize and stabilize
        Procedure
        1. Call the Service Mode to the screen.
        2. Touch [Imaging Process Adjustment] -> [Stabilizer].
        3. Touch [Initialize+Image Stabilization].
        4. Press the Start key to start Stabilizer.
        The Start key turns orange and stays lit up orange during the Stabilizer sequence.
        5. Stabilizer is completed when the Start key turns blue.
        Then Run your Gradation Adjustment on a high grade paper making sure you put 10 sheets on top of the test pattern before scanning it. I would run it a minimum of three times for each setting.
        • copier tech
          • 8144
          Good Morning,
          Is the device on genuine toner ?
          • femaster
            • May 2011
            • 1504
            On my PC screen, even though the second image is what it is supposed to look like, that one looks bad to me. The people look way to "red", like they have a serious sunburn. The first one looks more "normal" to me. Could be many factors that affect that though, my uncalibrated monitor, poor color recreation when scanning you originals, etc. Just saying I like the first image better, but that's just me.
            At this point, I'd follow Markks advice and see what comes of it.
            • allan
              RTFM!!
              • 5462
              +1 Initialize and stabilize. Check that all the settings under Image Process Adjustment are set to default first.
              Can be that yellow or cyan could be under or over saturated.
              Whatever
              • allan
                RTFM!!
                • 5462
                Are we on the same machine here?
                Whatever
                • allan
                  RTFM!!
                  • 5462
                  Home Care Services | Care Visits At Home | Bluebird Care
                  That does not seem to be green that would be more to cyan. These new drum units seem to suffer from cleaning blade failure on cyan due to heave coverage.
                  The only thing off here may be you customer...
                  Whatever
                  • femaster
                    • May 2011
                    • 1504
                    Originally posted by Doodlewo
                    This may be due to different factors, such as an uncalibrated monitor and problems with color reproduction when scanning.
                    Yes, I literally pointed that out in my original post, but thanks for reiterating that.
