Machine lost settings due to the dead battery issue. I had good machine so took MFP board with good battery to swap out. I used the original SSD, HDD & memory and transferred to good MFP board. Was not able to get into service mode to backup settings, etc before using the reset F/W.
After using the reset F/W I went through the installation setup, input serial #, time, etc.
Thought everything was good when it printed a perfect demo page. But when I went to copy the config page from ADF or off the glass the page is purple with garbled white marks where the print is supposed to be. Reseated all connections on the MFP board, did gradation adj, etc. Nothing fixed issue.
See attached pics of purple page & good demo page. Again printing to machine is fine, only copying & scanning has purple issue.
Thanks for any help.
