Bizhub c450i / c550i Toner Hopper Guide
  • mojorolla
    The Wolf
    • 2627
    We have had a few of these hoppers fail with various issues. Had some time this week to throw this together and I hope it can help someone in the future. Enjoy
    Not allowing a 2.5 MB upload, tried from 3 browsers, I will check in later
  • ronny2502
    • Mar 2020
    • 79
    Re: Bizhub c450i / c550i Toner Hopper Guide
    Hello,
    what about a short written summary about what you mean?
    Ro
    • tsbservice
      Field tech
      • 8020
      Originally posted by ronny2502
      Hello,
      Ro
      How about waiting a bit before making snarky comments?
      • Albonline
        • Sep 2008
        • 1151
        The main problem with these hopper/toner supply units are the photo sensors underneath where spilled toner WILL fall into! sort of causes a chain reaction of starved developer because sub hopper never askes for toner.
        • tsbservice
          Field tech
          • 8020
          Make it PDF or zip that way it should work.
          • mojorolla
            The Wolf
            • 2627
            3 days now, wont accept the file. Dropbox it is then:
            Dropbox - c550i TONER HOPPER GUIDE.pdf - Simplify your life
            Sorry for the delay.
            • tsbservice
              Field tech
              • 8020
              Thanks mate I tried to upload pdf and zip from device and web both won't work as advertised.
              I'm going to try to contact Aneurysm about that.
                • 23009
                1 MB is the limit on our attachments to threads. We're also limited by file type. It appears that you found a workaround.
                • rrrohan
                  • Sep 2011
                  • 1977
                  the troubleshooting info is helpful i wasnt aware of the sliding gear problem. we wear black pants at work so i generally dont like turning the hoppers upside down
                  • mojorolla
                    The Wolf
                    • 2627
                    The interesting part was the springs were put on backwards from the factory. Of the 4 springs, 2 were backwards.
                    Not a fan of the "i series" machines
                    • mojorolla
                      The Wolf
                      • 2627
                      Interesting. At the bottom of the attachment windows, it shows this max file size chart based on file type:
                      Curious what this list is referring to then.
                        • 23009
                        [ATTACH=CONFIG]60338[/ATTACH]
                        LOL! I never noticed that. The largest file I've ever successfully attached is 1.18M. =^..^=
                          • 37524
                          When I click on the attach paper clip there is a ? in a blue circle near the top right. Clicking on it I get a similar list except it has 2 additional columns, max width and max height.
                          • Ziggy
                            • Feb 2018
                            • 766
                            Konica has this bulletin on the toner hopper
                            • mojorolla
                              The Wolf
                              • 2627
                              I took a cropped screenshot, I see those columns as well slim.
