C454 floor finisher paper stuck top
  • cube10025@gmail.com
    • Aug 2022
    • 55
    Hello, does anyone have a tip?
    A customer has a floor finisher on a C454, and paper gets stuck at the top. It appears the rolls can't grab down to the folder. When I lift the top, the paper gets stuck in the same place. I can't see anything obviously wrong. Is it possible that the finisher is misaligned with the printer? See photo, just under the black bar. (Photo not the same finisher)
    • 14972
    Re: C454 floor finisher paper stuck top
    [ATTACH=CONFIG]60714[/ATTACH]
    A jam code would be very helpful in suggesting any solutions.
    Also, is the gate directing the paper along the correct path?
      • Aug 2022
      • 55
      There is just a general jam, It appears direct the paper. Thing is I got 3 other finishers with the same problem so I assume its a common problem, unrelated to this machine.
      • kingarthur
        • 1385
        Go into the service mode, and tell us what the jam code is, it'll probably start with "72"
          • 23010
          We've all worked on tons of these finishers, but we really need a jam code to offer useful advice. =^..^=
            • Aug 2022
            • 55
            Sorry just realized it is not KM but Lexmark, XC9235. I do have another finisher on C454 with the exact same problem but now suddenly it works so no error code. I think is had to do with the middle transport rather than the finisher itself.
