I Series C250i C360i Stuck At 25%
  • aberock
    • May 2022
    • 119
    Hi ,
    Recently few unit of our rental machine C250i facing freeze screen , stuck at boot screen .
    We tried update to latest firmware but machine fail to update f/w .
    Check the ssd looks like a normal storage card , is it possible to put in new m2 in there ?
    ( it work by replace other machine ssd , but i hope can work on the old drive to save it )
    Any one got the file / boot rom to put in the new storage board so it can update f/w ?
    I try to format the whole ssd but no luck .
    Perhaps any one can give a guide / file to solve the problem .
    Thanks.
  • Gift
    • Mar 2011
    • 2459
    Re: I Series C250i C360i Stuck At 25%
    This issue kind of faded away - I think this year we only had one faulty nVME.
    Therefore I didn't really investigated any further about fixing a "NG" flagged nVME or using one from a PC part supplier. I was also able to format a so-called faulty nVME with an external adapter and after installing it back in die MFP the partitions are rebuild by the machine, still it won't work. I had a few ones that I couldn't send in as warranty case - these are running fine in several computers/laptops now
    • kingarthur
      • 1338
      turn on the device, while holding down the subpower button, the one on the left of the panel. once you've done that, post what the 3 lights are doing, static/flashing - this will help diagnose the problem
      • aberock
        • May 2022
        • 119
        yes ! look like need some boot rom so machine can recognise the new hdd
        but I don't know how
        • Synthohol
          Certified Konica Expert
          • 5808
          you can try the GXX diag/repair firmware that may fix it.
          • Synthohol
            • 5808
            Setting value Default setting
            Storage
            microSD
            • aberock
              • May 2022
              • 119
              Storage
              microSD
              I cant enter to Service Mode sir.
              Will stuck at 25% screen , can't boot in .
              • Synthohol
                • 5808
                the GXX diag tool i suggested to run first, i just jumped ahead
                the GXX tool will either identify the storage as a problem or the CPU itself.
                let us know.
                you tried booting while holding down the hidden reset button?
                if the dot appears in the corner you may get lucky and boot into trouble reset screen and be able to access service mode from that screen using the normal S00S01
                • Gift
                  • Mar 2011
                  • 2459
                  Wasn't it possible to cheat yourself into the service mode by booting from fw stick (or diag tool)?
                  • aberock
                    • May 2022
                    • 119
                    let us know.
                    yes I tried hold the reset button to make trouble reset appear but only dot appear in screen the infinite waiting.
                    dot appear and freeze machine no more loading
                    • Synthohol
                      • 5808
                      then the GXX file should be next.
                      • copier tech
                        • 8133
                        Here is a troubleshooting guide on this issue. It maybe of some help.
                        Bizhub i series diagnosis and recovery for bootup issue.pdf
                        • tsbservice
                          Field tech
                          • 7999
                          Can you confirm it? Never manage to did it from fw mode screen or diag tool screen.
                          • HoonBoy
                            • May 2011
                            • 130
                            I guess you will need to replace the CPU Board.
                            • Scope
                              • Feb 2022
                              • 16
                              Follow this procedure to recover the Storage board then the Boot Rom, Ive had great success with this
                              Boot room recovery.pdf
