Interesting stuff
  • tsbservice
    Field tech
    • 8019
    Interesting stuff
    We just installed few KM A3 machines(300i and C250i) 2 of them with dirty glasses on the bottom side, one dot was on slit glass and another on original glass. Installed hundreds and first time seeing this. They must have monkey for quality control or started drinking too early 😂
  • mojorolla
    The Wolf
    • 2626
    Re: Interesting stuff
    I used to joke that the "i" series stood for "incomplete" but have changed that to "I spend a lot of time on these boxes."
      • 23008
      That's kinda disappointing on new machines ... but it's better than physical damage. I've straightened a few upper frames, because the fuser door wouldn't latch. I would have liked to returned the device, but we could have waited another forever for a replacement machine. The scanner took most of the hit, but amazingly, mostly damaged only the upper frame around the fuser. The scanner survived, with a little tweaking.
      • tsbservice
        Field tech
        • 8019
        Yes and yes, I mean we're all used to get broken machines happened a lot to us but oddly it's very first time we get that minor issue.
        To the point we looked at the drum, belt and fuser before actually spotted the dot under slit glass
        I mean nothing dramatic happened just wanted to share with friends around.
        Good luck all and remember better dot under glass than broken scanner
        • wjurls
          • Feb 2017
          • 498
          [ATTACH=CONFIG]60913[/ATTACH]
          I say it stands for "incomplete" too LOL.
