C308 printing black only
  • copyman
    Owner / Technician
    • Sep 2005
    • 4718
    Haven't seen this before on 8 series. But think I've read on forums about this but couldn't find it. Customer called and said will print black only. Color drums are at 0% but all consumables / reminders are turned off in enhanced security mode, etc.
    Is there a soft switch that needs to be set?
    Customer is far away and would like to help them fix this issue over the phone so I can wait until next time there and will bring drums at that point.
    Thanks in advance!
  • tsbservice
    Field tech
    • 8020
    Re: C308 printing black only
    Is there any message on machine screen? In your situation I would call them and ask for remote desktop then setup remote panel and see what is on machine screen and double check all CE settings etc.
    • dibyendu2008
      • Dec 2011
      • 27
      I think any one Colour Toner is empty. please check all colour toner avaialable quantity in machin.
      • copier tech
        • 8172
        Thanks in advance!
        Sounds like the life stop setting for image units has been enabled.
        Enter CE mode, then press stop 0 C this will take you to enhanced security mode where this this be turned off.
        • copyman
          Owner / Technician
          • Sep 2005
          • 4718
          [ATTACH=CONFIG]60920[/ATTACH]
          Thanks but like I mentioned in OP all consumable life settings including enhanced security mode have been turned off. I automatically do this with all off lease machines I sell.
          • Synthohol
            Certified Konica Expert
            • 5847
            sorry if i missed it but have you looked at the pagescope webpage?
            sometimes there is a message in red that could help?
            or they can logon and send a screenshot to you?
            • Max
              • Oct 2011
              • 561
              Sometimes it's a glitch. Even if every life setting is turned off it still doesn't print. Switching it off and back on resets it. Sounds simple but it does work sometimes.
                • 14810
                With an 8 series machine consider yourself lucky that the drums even made it to yield. You might as well bite the bullet and install new ones, you will be getting a call soon with quality issues anyway.
                • tsbservice
                  Field tech
                  • 8020
                  I have surprisingly few of them making around 150% but those are odds and are in clients with low coverage and high volume. Other than that you are absolutely correct, after they reached 0% it's a matter of time.
                  • copier tech
                    • 8172
                    I disagree with this. I have many devices with drums expired & the quality is still perfect.
                    They are run on genuine toner so I assume yours aren't.
                      • 14810
                      I have worked on 8 series machines since their launch and the drums have never lasted much past yield, OEM toner or otherwise.
                      • Synthohol
                        • 5847
                        i was carrying 8-12 DR314s as trunk stock because they sucked so bad and machines only ever used oem supplies and parts.
                        the charge rollers are just pathetic IMHO.
                        • tsbservice
                          Field tech
                          • 8020
                          313/315 i believe it's typo. 8 series low speed color office machines aren't bad at all IMHO.
                          We have a lot and most of them perform well under average usage. Those heavy used are our champs, I like Konica Minolta for that reason. You put them on stress and they just perform.
                          • KMFLT3CH
                            • May 2017
                            • 241
                            Came here to say this, I've come across this problem a handful of times on various models.
                            Re-enable all the life stop settings in service mode, tap End then back out to the ready to copy screen. Machine will probably be lit up like a christmas tree with all the warnings. Then back into service mode and disable all the warnings/life stop. Should be good then.
                            • kingarthur
                              • 1369
                              I've got quite a few machines out there, that the drums have done nearly 3 times their life, and the cq is fine
