Bizhub C224e: Problem with printing cyan
  • Leonard590
    • Jan 2024
    • 2
    Greetings kind strangers,
    we recently got hold of a used Bizhub C224e that has a problem printing cyan (the other colors are printed correctly).
    This is what the gradation test looks like (printed on A3).
    Consumable life is given as follows:
    Developing Unit 98%
    Drum 69%
    Transfer Roller 92%
    Image transfer belt 69%
    Can you point me into the right direction as to which unit may cause this problem?
    Kind regards
  • techsxge
    • Jan 2022
    • 660
    Re: Bizhub C224e: Problem with printing cyan
    Could be a Drum issue. Switch the cyan drum with the yellow ormagenta one and see if that changes anything
    • tsbservice
      Field tech
      • 8052
      In this case switching drums has nothing to do with depleted developer.
      Time to call good KM tech.
      • techsxge
        • Jan 2022
        • 660
        but the pattern looks more like drum to me?
        or am i really that sick that i cant even recognize the error pattern anymore?
        • Albonline
          • Sep 2008
          • 1153
          [ATTACH=CONFIG]61173[/ATTACH]
          Developing Unit 98%
          Drum 69%
          Transfer Roller 92%
          Kind regards
          the developer unit is empty, you will need to determine why and refill, or better yet replace the cyan units. the charge system in the drum unit is probably fouled from toner mist.
          • copyman
            Owner / Technician
            • Sep 2005
            • 4762
            Cyan developer dumping is a common issue most of the time because of over life drums shorting out. You will need to replace any overlife consumables, especially the cyan drum & add developer. Since dev units are so expensive I use aftermarket developer powder to fill dev unit that has dumped. Get level in state confirmation to 6+%
            If you don't replace the over life consumables developer will dump again and you will go through this all over again!
            • copier tech
              • 8200
              This is 100% correct, we see this multiple times per month.
              You need to replace the DV-512C cyan developer unit part number A2XN0KD
              • copyman
                Owner / Technician
                • Sep 2005
                • 4762
                I also see this multiple times per month.
                Repeat... you do NOT have to replace complete DV unit at $500 each! Just buy a bag of aftermarket cyan developer for $30, add around half a bag using a funnel while turning gear on end.
                I do recommend using "genuine" toners in all the Kon/Min color models.
                • Hansoon
                  • Sep 2007
                  • 3391
                  • techsxge
                    • Jan 2022
                    • 660
                    • copyman
                      Owner / Technician
                      • Sep 2005
                      • 4762
                      Agree the OP's photo shows a classic example of depleated developer. But the reason it depleated has to be addressed and that is usually an over life drum. That is the point I was trying to make.
                      • kingarthur
                        • 1385
                        Definite DV unit depletion, as well as replacing cyan DV unit, possibly the drum too as previously stated, any units over life need replacing - but you may also have to reduce the TCR level for cyan by 1, so go from 0 to -1. if the problem reoccurs, then go down to -2, you can go as far as -3. it's under Image Processing Adjustment
                        • tsbservice
                          Field tech
                          • 8052
                          All of this stuff plus I tend to replace ozone filter and clean ducts after removal of drums, devs and belt. I also use Konica jig for vacuum cleaner whenever it's possible(higher speed machines).
                          • allan
                            RTFM!!
                            • 5462
                            The cyan air vacuum duct does not work as well as for magenta yellow or black on the 55ppm and lower 4 series machines. Design issue I would think. On ever call I remove the cyan drum and clean off the charge assembly with a brush and a syringe bulb to blow out loose toner. Cleaning the toner filter also helps, that is if that model come with one. The toner on the charge assembly will cause all kinds of issues including drawing the developer out of the dev tank. Every 200K prints or so I remove the developer tank and clean out the dusting suction ducts then I use a long pipe attachment I made for this task to clear out the suction port entrances that gets clogged.
                            Easy enough to just top the developer up again.
                            Whatever
                            • tsbservice
                              Field tech
                              • 8052
                              Originally posted by allan
                              On all the 4 series machines (55PPM and lower) there is a design issue with the air suction duct that vacuums out toner dusting due to normal operation. This is only the case with Cyan. Toner dust gets onto the charge corona unit leading to all kinds of trouble. On every service call I do on these 4 series machines I remove the Cyan drum and clean the charge unit with a brush and air that and cleaning the toner filter if that model has one. Every 200K prints I would recommend removing the cyan developer unit and use a long pipe attachment for your toner vacuum to suck out all the toner from the entrance to the duct.
                              Big Off topic:
                              Hey allan, I did Toshy 20 years ago with some great colleagues we were 'dream team' and we are still friends.
                              Nothing could stop us. If a was to choose 5 techs for second 'dream team' you will be instant choice
