Konica C224e - C364e series cyan dv units issue(and P.S. ads and popups on this site)
  • blazebusiness
    SanDiegoCopierRepair.com
    • 1257
    Nothing new, but this happens infrequently until now. Only posting due to a new trend, have had a huge increase of 4 series machines cyan dv units failing all of a sudden in the last 2 months on these models. Using oem drums and toners of course and not past life. When the dv unit goes bad / depleted, the coronas get full of blue toner. Almost always seems to be the cyan that goes bad.
    Gonna try and phase out the remaining 4 series we have in the field and put 8 series or i series units in place instead.
    P.S. Copytech site has been a great resource but the popup of ads is so annoying that I find myself using the site less and helping others less than I would like to. I would contribute/donate more $$$ like I've done in the past if that would result in the popup ads being removed. We always had banner ads but that wasn't really a bother like the popup ads.
    Anyway, the fix is always - replace the cyan dv unit (and replace oem drum unit which shouldn't ever be run past life) and it is essential to never run the cyan tcr over the 0 level. Better even to reduce that tcr setting to -1 or so, but never increase it. Install the dv512K and swap out the wire and guide and the K DV reset chip will work for the colors.
  • tsbservice
    Field tech
    • 8052
    Re: Konica C224e - C364e series cyan dv units issue(and P.S. ads and popups on this s
    You should come here more often.
    I use add blocker and it doesn't look bad at all with it.
    Lately Admin is back on its duties so we're in good overall shape excluding average forum's member age 50+ I believe... which is good after all I would trust Slim or BC waaaay more than youngsters.
    We seem to settle politics outside of tech forums which is also right and needed move...
    The most missed are good techs with a lot of experience so Welcome back 🙂
    • Synthohol
      Certified Konica Expert
      • 5892
      i use firefox exclusively and use the adblocker ultimate and popup blocker ultimate and im no longer bothered by them.
      there is popup/ad blockers for mobile devices.
      • wjurls
        • Feb 2017
        • 501
        Replace them with 8 series, not I. FWIW Copylite now carries a universal DV unit (fits the 4's, 8's and i's) for the small color Konica's that work fantastic for $330 each.
        • blazebusiness
          • 1257
          Agree totally, I prefer the 8 series also, at least until all the i series bugs are worked out.
          Great info on the universal copylite dv units, thanks for the heads up.
          • blazebusiness
            • 1257
            The most missed are good techs with a lot of experience so Welcome back ��
            I'll have to download a reputable add blocker then ........ good idea.
            • larweedad
              • 93
              On the ad blocker, I use uBlocker for quite awhile. works great on you tube also.
              • KMFLT3CH
                • May 2017
                • 242
                uBlock Origin and Privacy Badger is all you need. Still blocks youtube ads and that dumb overlay/warning they've been rolling out. These days no one should be browsing without an ad blocker IMO.
                • femaster
                  • May 2011
                  • 1519
                  I'll second uBlock Origin (makes sure it has ORIGIN in the name, the one called uBlock is a fake). I've heard of Privacy Badger, but have yet to try it out. Someday I might dig into it.
                  • tsbservice
                    Field tech
                    • 8052
                    Off-topic
                    Hi KMFLT3CH. I'm about to follow your advice here, would you confirm those are correct ones and any recommendations for them based on experience, see links.
                    TIA
                    uBlock Origin - Free, open-source ad content blocker.
                    Privacy Badger
                    • blazebusiness
                      • 1257
                      Off-topic
                      TIA
                      Privacy Badger
                      I can confirm the ublock origin link and it has worked very well for me............I haven't tried the privacy badger.
                      • KMFLT3CH
                        • May 2017
                        • 242
                        Yes, those are the exact ones I use on Firefox.
                        On privacy badger there are a few settings to change if you want to block the youtube video blocking overlay they rolled out when using an ad blocker. It's basically a countdown that says hey, you're using an adblocker, you can watch 3 more videos before we block your access completely. Google the Reddit thread for more info on how to disable that.
                        On uBlock you can go to settings and Filter Lists to enable/disable certain filters, don't forget to apply changes then update.
                        • copier tech
                          • 8200
                          The long term fix is to vac out the rear airducts, they clog up causing this exact issue.
                          Bit time consuming to do but it does work.
                          I also use adblocker, works a treat on here (don't tell admin )
                          • EarthKmTech
                            Step aside, noob
                            • May 2009
                            • 2139
                            been using adblockers for years, hard to beleive people tolerate the number of ads out there these days. Youtube is the worst now, unwatchable without it.
                            In addition to the mandatory duct vacuuming, I was also running cyan TCR manually set to -2 or -3 which also helps reduce the toner puffing off the dev roller contaminating the drum charge then the machine overcompensating and stripping the dev.
                            8 series on just works because a pcr just keeps working regardless of contamination, to a point. When both versions are working as designed, the pcr version produces inferior print quality though. I do not like 8 series print quality compared to 4/4e but i guess its a hell of a lot less hassle.
