Konica Minolta Bizhub C250i market place
  • Alex1
    • Oct 2012
    • 285
    I have a Konica Minolta Bizhub C250i and wanting to reset the market place for a new customer to use it to be able to scan to email using office 365 apparently there's a app on market place which supports office 365, any help with the reset us appropriated.
  • Synthohol
    Certified Konica Expert
    • 5846
    Re: Konica Minolta Bizhub C250i market place
    the i series supports O365, no app needed.
    • Alex1
      • Oct 2012
      • 285
      Yes I am aware of that but the customer is wanting to use konica market place and the serial number is registered to another account l. Is there a way to reregister the serial number from the existing account to a new account?
      • rrrohan
        • Sep 2011
        • 1977
        whats marketplace got to do with simply emailing via office365.
        Im guessing you want to scan to SharePoint as that would make more sense
        • Alex1
          • Oct 2012
          • 285
          Yes correct that's what the customer is requesting
          • rrrohan
            • Sep 2011
            • 1977
            dont make same mistake as me and get SharePoint. 99% of customers these days actually need SharePoint Online.
            • kingarthur
              • 1366
              As far as I'm aware, the previous owner needs to remove it from their account - probably should've been done before they gave it back
              • emujo2
                • Mar 2017
                • 1579
                I'm a little confused..is the App already loaded into the marketplace?
                Here's what you should be doing..
                1. The customer needs to create a marketplace account.
                2. The customer needs to purchase the required app.
                3. You would log into the marketplace with the new account info.
                4. Go to purchased tab and download.
                5. Configure App in marketplace
                6. Sign into app after launching. You must have an established account to use..
                • Alex1
                  • Oct 2012
                  • 285
                  I thought maybe it's something that can be reset, then set up to the new customer, however the serial number being registered to the existing account it can't be done.
                  • rrrohan
                    • Sep 2011
                    • 1977
                    does it link to a account? i thought it just connected to what ever marketplace account signed into it. ive logged in to 2 separate accounts of marketplace on one device with no problems
                    • Alex1
                      • Oct 2012
                      • 285
                      It keeps saying can't connec, to check network connection however it's got a ethernet cable plugged into it.
                      • Synthohol
                        • 5846
                        you need a good gateway and DNS to reach the outside world.
                        in admin mode in network you can ping like google.com or msn or some other live site. if ping fails that machine is not on the internet. intranet maybe but not allowed outside the IP range.
                        • Alex1
                          • Oct 2012
                          • 285
                          It was giving the same message in my workshop and at the customer's site when ever I select the marketplace app on the home screen.
                          • Synthohol
                            • 5846
                            thank you however that wont answer my question.
                            have you checked gateway and DNS and ping'd an outside web address successfully?
                            if not, id start there.
                            shotgun approach-->do a network initialization and use DHCP to verify connection to the outside world by pinging a web address in admin mode successfully.
                            • Alex1
                              • Oct 2012
                              • 285
                              I'll give it a go and test the network however I think the network is fine. I'll let you know.
