Shift image to one side
  • Promise
    • Jan 2024
    • 19
    C452 shift print out to one side of the paper both in tray and bypass plz check attached picture A95D3549-79A2-48A0-B8DC-5936679BE15B.jpg
  • Synthohol
    Certified Konica Expert
    • 5824
    Re: Shift image to one side
    kill it with fire.
    seriously though, id initialize the machine in service mode, install firmware again and run the calibrations.
    thats so far out of an adjustment range i wouldnt even try.
    what i would do though is maybe reseat all the ribbon cables to the PRCB and MFPB.
    good luck.
    • femaster
      • May 2011
      • 1504
      Not just shifted, but it looks compressed as well. Not really sure what to say about that. I assume it happen with everything including prints and copies off the glass (not ADF)?
      • Albonline
        • Sep 2008
        • 1150
        agree on the shrink. is image on the belt shrunken also? 2nd feed /timing roller bound up?
        • Synthohol
          • 5824
          there is also not a hint of yellow on that page.
          have you done anything so far?
          • elmaligno
            Expert technician KM
            • Oct 2009
            • 302
            Originally posted by Promise
            C452 shift print out to one side of the paper both in tray and bypass plz check attached picture [ATTACH=CONFIG]61887[/ATTACH]
            Yellow is missing. Start there and then reset + stabilizer.
            Field technician since 1994
