IC-418 "FF" after running updates
  • JasonSBE
    • Apr 2014
    • 183
    Evening, all.
    As stated, I had 6 or 7 updates for my Fiery controller for a bizhub C659. I decided to go ahead and install them, but when the controller rebooted it went to a "FF" fault. I can ping it, but cannot communicate with it via command workstation or the web ui. I know the FF fault generally means an issue with the motherboard or cpu, but since it happened at an odd time I'm going to reinstall the software in the morning with a USB drive, and double-check all the connections. If anyone has any other ideas on what I should check for, it would be greatly appreciated.
  • Ziggy
    • Feb 2018
    • 679
    Re: IC-418 "FF" after running updates
    Originally posted by JasonSBE
    Evening, all.
    I would replaced the HDD with a SSD. Fiery will boot and run much faster. Plus with that error you could have a bad HDD . I believe this fiery takes a 500gb hdd, you can get a 500gb SDD for $40.00 us .
    • mevaser
      • Dec 2024
      • 12
      Did you ever solve your issue? I have exactly the same Fiery and did exactly the same updates and ended up with exactly the same issue. Fiery controller won't go past "FF". It was working just fine before applying the patches. I actually applied one and rebooted. And it still worked fine ("OO"). But then I applied all the rest at once. I wonder if that was a mistake? Would appreciate any help...
      • Ziggy
        • Feb 2018
        • 679
        If you loaded them manually then you need to read the instructions for each update. Some are exclusive updates and cant be loaded with ant other update. there are sometimes other information about the update. If you allow command workstation to do the update it will load them in the correct order. just know the fiery could possibly reboot several times depending how many updates there are. Just be patient , I would start the update process in command workstation at end of day and let it run overnight. Even on the new fiery's they are super slow about booting. I've had the new fiery's take as long as 25 minutes on first boot up. When working with fiery's pack your patience's
        • mevaser
          • Dec 2024
          • 12
          I wonder if I messed up the processing by manually rebooting before it was finished. At this point I can no longer connect to the controller through Command Workstation or through the device (KM C659) it is attached to. I left it for 36 hours. When I went in this morning it was still reading FF. I tried rebooting manually a couple of times, even disconnecting the power supply. Still locked out of the Fiery. What do I do next? Do I need to reload the operating system?
          • copyman
            Owner / Technician
            • Sep 2005
            • 4524
            Reload OS and good advice about upgrading to the SSD.
            • mevaser
              • Dec 2024
              • 12
              Can someone walk me through the proper procedure for reloading the OS? I just got this controller used and it didn't come with a USB with a backup. I need to knew where I can find the right OS and instruction on how to reload it...
              • Ziggy
                • Feb 2018
                • 679
                I would replace HDD with a SSD and reload. Just make sure your SSD is the same capacity as the HDD
                • Ziggy
                  • Feb 2018
                  • 679
                  If no one replies before I get off work, I will post instructions later today
                  • Synthohol
                    Certified Konica Expert
                    • Mar 2016
                    • 5735
                    sys soft reload. 418.pdf
                    • mevaser
                      • Dec 2024
                      • 12
                      Thank you so much Synthenol and Markks for your valuable input and system reload instructions. This machine didn't come with a DVD. Can you help me find the USB helper tool and system and user software (ver 2.0/3.0?)? I plan to do as you suggested and replace the HD with an SSD. Also, is it possible to create the install USB on a Linux or Mac? I am trying to move away from Windows...
                      • Synthohol
                        • Mar 2016
                        • 5735
                        • Windows 7, Windows 8.1, or Windows 10
                        the tool is windows software only so no go on mac or the cool penguin.
                        • mevaser
                          • Dec 2024
                          • 12
                          Ok, Windows 7 it is. Is there a download site for the software I need? Also, does anyone know the recommended OS version for the 418?
                          • copyman
                            Owner / Technician
                            • Sep 2005
                            • 4524
                            PM me your email and will send USB tool & OS
                            • copyman
                              Owner / Technician
                              • Sep 2005
                              • 4524
