Replace Hardrive C458. and color patern on scan
  • cube10025@gmail.com
    • Aug 2022
    • 55
    I have a C458, when I scan I get a color pattern on all the scans. It prints fine. There also appear to be a problem with the harddrive as the printer refused to boot swapped the drive with SSD and the machine boot but I can not format the new drive. So do I need a specific drive or is there something else wrong with the machine?
  • tsbservice
    Field tech
    • 8019
    Re: Replace Hardrive C458. and color patern on scan
    Can you enter admin mode? Format can be done there.
    • Duplicator
      • May 2022
      • 246
      A blank disk is fine but it needs to be larger or the same size as the original disk removed from the machine.
      If memory serves correctly, they stamp a partition table onto the disk in a set size. If the disk is bigger it just leaves empty space unused at the end of the disk.
      Worked in IT for 12 years from Helpdesk up to System Administrator. Now working as the IT Manager at a copier company for the last 4 years.
      If I helped you out, please give me a thumbs up! It helps my reputation.
        • Aug 2022
        • 55
        • Ziggy
          • Feb 2018
          • 758
          try running the reset tool. but even though the hdd was able to be formatted there is a chance you could have a bad hdd. If memory is correct I believe that machine has a 328gb hdd. I have used 500gb ssd with no problem
          • tsbservice
            Field tech
            • 8019
            I won't run reset tool because of bad HDD. Another one with same or bigger capacity and machine will use what it needs after format. SSD should be OK too but I never tried it on 8 series.
            • Ziggy
              • Feb 2018
              • 758
              Your right, I should have clarified my answer better. If you know hdd or ssd is good and machine wont boot then try the reset tool. I have put SSD in several 8 series with no problem. The way I do it is boot straight into service mode via the reset screen and do a logical format of the SSD then turn off and the load firmware
              • femaster
                • May 2011
                • 1508
                Minimum size drive would be 320GB. You can use larger, but needs to be at least that big.
                • Duplicator
                  • May 2022
                  • 246
                  It is possible to format bad HDDs and for the Konica to think it's "fine". It is just a computer hard disk really. All the usual sets of tools work. Things like Spinrite, SMART status utilities, ect. When we pull a hard disk it gets tested for SMART status. We find many of them that have re-allocated sectors (disk is failing). If it's going to be used as a spare it gets the partition table blanked before it goes into the next machine.
                  If it starts failing to boot again, Koncia has a document that contains "The Initial Operation during MFP start Up". Essentially it's a chart of lights and items displayed on the screen that help diagnose a machine failing to start.
                  Thanks, couldn't remember the right size.
