how to change the count of an A3 sheet
  • giordaxx
    • Mar 2024
    • 6
    Hi everyone... do any of you know how to change the count of A3 sheets? Let me explain better... when I photocopy or print an A3 sheet the machine counts 2 copies made, because the A3 is considered as 2 A4 sheets. Instead, I want the A3 sheet to be counted as an A4 sheet, so only one copy added in the machine count.
    The machine in question is a konica minolta c284e
  • Brad6784
    • Mar 2015
    • 84
    • Synthohol
      Certified Konica Expert
      • 5905
      Re: how to change the count of an A3 sheet
      OP sounds like they could be an end user with a by-the-click service contract and is about to screw the servicing company with your help.
      or am i being paranoid?
      • femaster
        • May 2011
        • 1526
        If you are being paranoid, then so am I. I had the exact same thought when reading his question, and then seeing the response on how to change it. Looking at the join date of last month and only 2 posts in the forum so far, end user is exactly what I was seeing.
        • kingarthur
          • 1390
          I was going to comment the same - but i thought, it's probably my paranoia too
          • Synthohol
            • 5905
            i remember a customer doing that themselves and the CQ and drum wear was way down at 60% and the way i caught it was on the meter sheet A3/11x17 still clicks as "LARGE" (for reference) on the page and still shows the count by size. it just clicked the main totals 1 click but simple math (and the amount of toner used) showed they set to no-count for tens of thousands of pages. we back billed the snot out of them and dropped the contract terms to labor only.
            • allan
              RTFM!!
              • 5462
              +1. Someone is getting screwed over.
              I have been asked this from dodgy end-users before.
              Whatever
              • allan
                RTFM!!
                • 5462
                Hi please post the meter counter page to check the setting.
                Whatever
                • Synthohol
                  • 5905
                  consumables go by minutes of use anyway so i dont see the point other than some shady AF reason.
                  • rrrohan
                    • Sep 2011
                    • 1977
                    if it end user then serves copier supplier for not changing the default CE password
                    • giordaxx
                      • Mar 2024
                      • 6
                      thank you all, you were available and thorough
