bizhub 601 paper jams in reverse registration
  • Davidsd
    • Apr 2024
    • 5
    Hello, thank you all, I am new to the community, my problem with the machine is:
    On a vertical letter sheet that is placed in tray 1 and 2, it gets stuck in my fingers of the cylinder, which means that the sheet lifts it, looking with the door open
    On a horizontal letter sheet the sheet passes normally but on one side, when I remove both sides the sheet reaches the cash register and gets stuck.
    Thanks, I will wait for your answers.
  • copyman
    Owner / Technician
    • Sep 2005
    • 4723
    Re: bizhub 601 paper jams in reverse registration
    Hi and welcome.
    Sorry but it's hard to understand what you posted? "it gets stuck in my fingers of the cylinder"? "sheet reaches the cash register"?
    I know copiers are expensive but never saw one with a cash register built in
    Perhaps it's a language or translation issue. Once the members here understand your issue better we can help.
    • Davidsd
      • Apr 2024
      • 5
      I forgot to mention that I changed the transfer crown wire, drum cylinder fingers and registration clutch
      • Gab
        • Aug 2015
        • 671
        have you checked that the 2 cylinders press each other. Perhaps at the side that paper doesn;t exit 2 rollers don't press each other
        • Davidsd
          • Apr 2024
          • 5
          Yes, sir, the paper does not rise horizontally, the problem is only vertical.
