Unknown error in the machine c250İ
  • suskunq
    • Mar 2024
    • 18
    good day friends
    The machine gives an error but there is no error code
    http://
  • doinbox
    • Jan 2013
    • 110
    Re: Unknown error in the machine c250İ
    Had this error recently and It seemed like it was because there was an issue with the test pattern on the belt. Turned out to be a faulty Dev unit for us. The dev looked fine but wouldn't appear on the print. Replaced it and the error went and then the machine let me calibrate. So I would check Imaging parts for any issues.
    • JMS
      • Apr 2023
      • 28
      • suskunq
        • Mar 2024
        • 18
        I ordered the transfer belt unit and I will write the result.
        • Gift
          • Mar 2011
          • 2459
          Originally posted by suskunq
          good day friends
          LOL 99-03 is the code...
          Let Me Google That
          • Black Cloud
            • 164
            I had this on a BH C360i. Image Stabilization Issue. In my case the Polygone was dirty and it was adding extra write lines, stretching the image and putting the patch out of range. The black developer became undertoned and lost some material. Clean the Polygone and then see if the stabilization completes.
            Net+ PDI+ @Remote
            • jwai
              • May 2018
              • 508
              I had same experience on C450i, performed TCR toner supply and fixed.
              • stronghold
                • Apr 2023
                • 47
                Look at this POST about 99-03
                • suskunq
                  • Mar 2024
                  • 18
                  transfer belt unit changed developer powder renewed The problem is still the same, image stabilization failed
                  • Mr Bo
                    • Mar 2023
                    • 28
                    Use Original toner and Replace new Deve Unit
                    • suskunq
                      • Mar 2024
                      • 18
                      Originally posted by mr bo
                      use original toner and replace new deve unit
                      the parts are very expensive here and i don't have the budget to replace them.
                      • rrrohan
                        • Sep 2011
                        • 1977
                        ive had heaps of problems with the i series tonner hopper. the sensor that flags hoppers fill status pops out so it thinks its full when its not
                        you can confirm this but physically adding toner to hopper
                        if tcr goes up you know hopper is problem and its time to remove it and inspect sensor arm. just vac it out then compare it to a colour with the issue so u know how sensor arm should be
                        just remove output top cover via left cover and 3 screws
                        remove drums and devs
                        remove front cover (about 7 screws) and attached doors
                        remove about 4 screw for hopper
                        its about 20 mins to remove
                        • suskunq
                          • Mar 2024
                          • 18
                          Originally posted by rrrohan
                          ive had heaps of problems with the i series tonner hopper. The sensor that flags hoppers fill status pops out so it thinks its full when its not
                          if tcr goes up you know hopper is problem and its time to remove it and inspect sensor arm. Just vac it out then compare it to a colour with the issue so u know how sensor arm should be
                          i will try it thanks my friend
                          • 4Toon
                            • Mar 2023
                            • 112
                            When you go into service mode do you have any P codes "oil can". I have ran into the blk drum being bad where you will see a mist of toner on the drum when you pull it out. I have heard of some techs having some success running Int/stabilize to get it to work but the easiest and fastest if you have one is to replace the drum
                            Permanently banned from Konica SSD.
                            • Cantechman
                              • Nov 2008
                              • 228
                              Clean the laser units
