C250i resets back to some factory defaults (almost) every Friday am!
  • Don N.
    • Nov 2011
    • 409
    We refurb & delivered a C250i about 3 months ago. We always flash latest fw (Q9) now, not the P that had issues, do an all data clear (which unsets the storage, reset to storage type (storage), format the storage. We use a thumb drive to import the same user & admin & network settings on every c250i which saves a lot of time. Everything tested from smtp scan, print, copy, adf, import our custom boot screen, set admin pw, etc...
    So cust calls on a Friday before noon. Its got a Konica logo screen, has reverted back to auto ip and has app button , some "announce" message (sorry, took a pic but cant find it now) and the marketpace button that we disable under IWS. Also reverted to 1~8, 1~8 admin pw which we only use 1~8.
    As soon as I put the address back to the old static address, they could print again. Very busy so I said lets let it go for now.
    Next Friday, it freaked again, locked up, wouldnt boot past about 25 or 50% (cust not sure) & back to auto ip address. I talked them throught static address setting back & ok tol next Friday. Similar stuff.
    It skipped (Good Friday) prior to Easter, although customer was working in office that day.
    Next Friday it freaked, they static it.
    Again today (you guessed it... Friday) it said something about run full diagnostics and had an unfamiliar boot screen accirding to cust. Started working after reboot for an hour or more, now "they xant use"
    Wish theyd gotten a pic of the screen & convey precise message but I was out of town. Ill ghave to deal with this in Monday am... Probably cleanse the main board with reset/tar file & reflash fw. Any better ideas? Thanks!
  • Don N.
    • Nov 2011
    • 409
    Re: C250i resets back to some factory defaults (almost) every Friday am!
    Wanted to add that their scan destinations were never lost and I might try repartioning the storage board, as that saved a couple of "bricked" i series that had P9 FW.
    • copier tech
      • 8220
      Sounds like a failing STRB or CPUB both can cause the same / similar issue.
      • tsbservice
        Field tech
        • 8064
        Run diagnostics and recovery tool also update boot ROM just in case. We are now rolling FW update for 1i series function version 2.3 on all our 0i series might have some improvements. Good luck.
        • Don N.
          • Nov 2011
          • 409
          My newest fw is Q4 or Q9? (Im not at the shop now).
          Youre saying theres newer 0i fw or your just using it independently?
          Also, Ive never updated a bootrom. Another file, sep from the recovery, or is it a choice in the process?
          What sequence do you recommend? Thanks.
          • tsbservice
            Field tech
            • 8064
            There is RB firmware for 0/1i will need switch 25 hex 40 to use function version 2.3.
            Boot program update is in newest firmwares after J9. I'm attaching it.
            • copyman
              Owner / Technician
              • Sep 2005
              • 4785
              Where is the diagnostic / recovery tool on the kon/Min delaer website? I took a quick look at the base & special F/W and didn't see it unless I missed it?
              I don't need it now but would like to have it for when I start selling more i series.
              • tsbservice
                Field tech
                • 8064
                Will be sending it to you at Monday.
                • Ziggy
                  • Feb 2018
                  • 810
                  Under special firmware search GXX that will pull it up
                  • copyman
                    Owner / Technician
                    • Sep 2005
                    • 4785
                    Thanks, I found it.
                    • tsbservice
                      Field tech
                      • 8064
                      Thanks, I found it.
                      @copyman do you still need it?
                      • Don N.
                        • Nov 2011
                        • 409
                        tsbservice-
                        Thanks for that. Not sure how to identify if it has the "Phison 96-layer storage board" so if it doesn't, is this boot rom still applicable?
                        • Don N.
                          • Nov 2011
                          • 409
                          TSBSERVICE
                          My account on this site has been screwed up for years. I can't send or rcv. PM and can't clear the message that I have 65,657 messages. No time to fart with it. If you can send the reset/diag. file to c o p i e r w o r k s a t G .... I would be grateful!
                          • tsbservice
                            Field tech
                            • 8064
                            TSBSERVICE
                            Don done deal wait a bit
                            • tsbservice
                              Field tech
                              • 8064
                              tsbservice-
                              There is procedure but you don't need it if your boot ROM is OK it will tell you don't need boot ROM update if it takes it then go ahead.
