Bizhub C250 error code C255B
  • markay
    • Aug 2025
    hi to all... i have a Konica Minolta Bizhub C250 which has failed me.
    after investigating the problem, here's what i have found out:
    error code c255b comes up after a few minutes after starting up (not letting me do any copies at all), i then open front panel then close...initialises (sounds like its constantly trying to do something) and then kicks in again with that error code c255b, and so on.
    i'v found out the meaning of that error code (and others which i have had previously not long ago eg. c2555 and c2654-> that one doesn't appear anymore). error code C255B = yellow TCR Sensor Adjustment Failure (i have the service manual .
    i'v noticed that in service mode / state confirmation / sensor check, that PC DRIVE DETECT for Color Main/Sub, Black Main/Sub and Waste Toner are always changing from 1 to 0 and 0 to 1.
    DON'T know if that is normal, so advice would be appreciated!
    i'v also noticed that in service mode / state confirmation / level history1, that TCR-C, TCR-M, TCR-Y, TCR-K are always at 0.00%.
    Finally, in service mode / counter / service call counter, the Yellow TCR Sensor has been displayed 13 times.
    So, does anyone know what exactly is wrong with my machine, is it very serious, is it fixable and if it is, how can i fix it.
    Many thanks too all!
  • abilashvk
    • 61
    hi friend,
    What's the life of yellow IU and counter reading? Sensor check might give U a changing value but U have to do a stabilisation procedure to get rid of that 0.00%.If your all IUs are good (and if there is no charge corona arching in respective IUs) make dev,bias ON in image process adj.,(then U can't make gradation adj.,) and observe for a number of copies.Try adding toner to respective IUs through TCR Toner supply.Take test copy pattern of all colors.If that also doesn't serve then may be a PWB-M or HV problem.A lot is it?
    • markay
      Hi... the Y Iu has almost reached it's 1st life cycle (but i'v got the machine working with the IU's "NO STOP" setting). it sounds like it's continously stabilising and only stops when the error message appears. i tried your advice, dev,bias ON ,but as it is always trying to do something (maby stabilising or supplying toner to the IU) it doesn't let me take any test copies and because the start button is always orange it also doesnt let me try the TCR toner suply.
      Oh yeh... i forgot to mention... just before the machine started to not work properly it gave out a buning smell
      btw... thanks for the help!
      • abilashvk
        • 61
        hi,
        Hope that burning smell has got something. It may be the arching smell of yellow IU charge corona(U can distinguish smell of it from spark of a component).Ur copier is trying to get the right mixture of T/C in all IUs-that's the turning sound indicates-But due to arching, drum of yellow(or any other IU) get fully charge exposed ,sucking of all toner from IUs to the transfer belt, which may resulting toner dry YellowIU. (Poor machine is again adding more toner to compartment) U may be now getting P codes also. Best option is a new set of IUs. Other wise this unused toner will spill over inside copier/laser heads creating new stories,OR U can dismantle the yellow IU and take out Charge corona of IUs,insulate END BLOCKS ,then pump enough toner and survive just LITTLE more time.
        • rprem
          • 49
          hai
          as abilash told change the iu and see any problem occurs or u put this imaging unit to some other cust machine and check it the same error code comes if it comes change the iu y
          Head Lines Are Made When Dead Lines Are Met
          • markay
            hi... after inspecting the situation further with the person operating the printer at the time, he says as it was not printing the Y color he was trying to clean (with a thin metal tip screwdriver) the connectors where the Y IU connects to (ON THE MACHINE) (not the big connector, but the small one above which has the small black plastic casing around it and four little connections), and in the process it did a little spark, and that the burning smell appeard when there was no Y IU installed on the machine.
            anymore ideas??
            • JSC
              Gimp
              • Dec 2006
              • 618
              anymore ideas??
              Yea, you need to kick the guy with a thin tip screwdriver up the arse..............he has shorted something and its not going to be a quick fix......call an engineer.
              The gene pool could use a little chlorine.
              • copytechman
                • Nov 2008
                • 947
                Yikes, sparks r never good! Yeah agreed, time to call a tech! Maybe took out the mcb... (or whatever the y iu directly connects to)... ouch...
                Regards.
                A.
                • mrwho
                  Major Asshole!
                  • 4299
                  Yeah, and then hand the bill to the operator who did this mess - and let him explain to his boss what happened! That will teach him!
                  Mascan42
                  Ibid
                  • abilashvk
                    • 61
                    hai,
                    unknowingly responded little further for this THREAD. Pls give details fully, truthfully also.We people are just assessing possible chances that can create a trouble.If somebody shorted the contacts then I'am Extremely sorry to say that ITS A FAULT FROM MY PART TO PARTICIPATE IN THIS THREAD. but any way, ask that fellow to enjoy that smell again by shorting another contact of next IU.
                    • mrwho
                      Major Asshole!
                      • 4299
                      I think that no one in this forum - you or anyone else - is at fault for this thread (unless the arse that that shorted the pins lurks in this forum ). I wish I had a cent for everythime I'm trying to find out what's wrong the machine when the operator is witholding information that could be helpful!
                      It's always nice when a techie asks for help and there's someone reading that can give a hand - and you did nicely!
                      Mascan42
                      Ibid
                      • edmund
                        • Jul 2009
                        • 29
                        Burning smell!!!
                        Check PWB-M board
                        it is mounted next to the power supply
                        There must be physical damage (burnt component on the board)
                        • abilashvk
                          • 61
                          hi friend,
                          Yes, most probably PWB-M faulty.I'am sorry for the technician.Check for any blown ICPs on PWB-M.This board ( A parameter chip seemingly DS2432 on MECH.CONTROL PWB holds life of IUs etc.,) relates directly to most problems related to P codes,Motors,clutches,timings etc., The burning Smell may related to some blown ICP.Carry out replacement test of PWB-M in another machine.PLEASE Involve that user/operator also in this procedures as atleast here after he may not short something in an elect. gadget.
                          Thanks & Goodluck
                          • markay
                            hi to all...
                            didn't realy understand some of the previous messages posted on this tread , but anyways... down to what realy matters, WHICH IS HELPING EACHOTHER AND LEARNING WITH EACHOTHER.
                            We have replaced the PWB-M board, machine starts like it used to, back to normal... but now when we print/copy, paper comes out completely white with no printed area. we will figure it out eventually ourselvs, but again, to whom is willing to be helpfull and kind, we will appreciate any help given as it will shorten down the time the machine is non-operative.
                            Please keep nonproductive coments to yourselvs, as they are absolutely useless and are a waste of pixels.
                            many thanks
                            • mrwho
                              Major Asshole!
                              • 4299
                              ? Okay...
                              /strolls away
                              Mascan42
                              Ibid
