BIZHUB 501
  • thuo
    • 155
    BIZHUB 501
    Bizhub 501 shows error d203.tried to reset the machine but code still persist.anybody with any sugestion on how to clear the error code.
  • moonwalker3778
    • Jun 2008
    • 87
    communication failure between OACB to Image controller IC-204. possible causes either OACB or IC 204. u try by removing IC 204 from OACB,may be u can fix it.
    • moonwalker3778
      • Jun 2008
      • 87
      sorry it is IC-207 not IC 204
      • DCPS
        • Mar 2008
        • 116
        Description
        The machine displays a C-D203 at power on.
        Solution
        Cause: The OACB (Overall Control Board) has failed.
        Solution: Before replacing the OACB reseat the NVRAM and Memory on board connections.If the issue is still unresolved replace the OACB (p/n A0R5 H010
        06).
        • 907tec
          • 434
          We've had similar problems with biz420/500. The tech bulletins list C-D203, C-E084, C-E081, C-E087 as pointing towards NVRAM problems. However, they also mention that updating the firmware can resolve many of these issues as well. I just updated the firmware on a problem machine yesterday, waiting now to see if we will have to replace the FW as well. FW is worth a try...hell of a lot cheaper than throwing new boards/nvram at the machine.
          • armaddon
            • Sep 2009
            • 11
            Possible other cause for CD203
            Not sure it helps much, but I just had a Bizhub 501 today with a sort-of similar issue.
            We were originally having problems with constant jams in the registration section and determined that the PRCB (pn 50GA-9020E - the other control board in the machine) must be faulty, so we ordered a new board. It arrived this morning, we installed in the machine, and instantly got a CD282 code on startup. Reboots would either get the same code, CD183, or sometimes the CD203 you are having. I tried updating the firmware, then even tried flashing the built-in CF card to the base version 10 and incrementally upgrading, but the CD203 code kept coming up over and over.
            I eventually gave up and just stuck their old PRCB back in just to see if the codes would go away. First power on was a success. Rebooted the machine repeatedly just to test and the code never came back. However, the registration jamming issue is still there (I've tested the multi-codes out and determined that the registration clutch among other things are NOT being turned on at all). I've since RA'd the supposedly brand-new PRCB and should be getting another new one tomorrow morning.
            Also, though this might be completely unrelated, I've had a few Bizhub C352s out in the field that throw this code occasionally for no friggin' reason, but it only pops up once only to not return for many months. Control boards/firmware/etc, all to no avail.
            • HuronMan
              • Jul 2009
              • 68
              Armaddon, Sounds like icp 4 on the prcb is blown. Here's a list of icps and fuses. Imageshack - 360420500icplist - Uploaded by huronman
              • copytechman
                • Nov 2008
                • 941
                Careful!! If you had the toner supply unit out for any reason and the toner solenoid off when you reassemble it, you can use the wrong screw(s) (longer ones) into the solenoid and short it to the frame and kill your control board (or icp 4 I suppose (never checked!))... its like that for the 420 series and would bet its similar for the 421 series as well! Just a though!
                A!
                • armaddon
                  • Sep 2009
                  • 11
                  Thanks for the info Huronman! - and yeah I remember those damned screws Never shorted a board myself but we had a tech do it AT LEAST three times...
                  • solis557
                    • Dec 2010
                    • 53
                    Re: BIZHUB 501
                    i would love to know what fixes this cause i have two doing the same thing. New boards and still the same problem! i have attempted to update the firmware from 10 and still throws error codes.
                    • Himmelsbote
                      • Sep 2015
                      • 1
                      Re: BIZHUB 501
                      Hi,
                      sorry for my bad english :-)
                      Zitat:"Careful!! If you had the toner supply unit out for any reason and the toner solenoid off when you reassemble it, you can use the wrong screw(s) (longer ones) into the solenoid and short it to the frame and kill your control board (or icp 4 I suppose (never checked!))... its like that for the 420 series and would bet its similar for the 421 series as well! Just a though!
                      A!"
                      i have the same Problem many times and i dont know what i do wrong.
                      everytime after the C2403 and change the sensor.
                      if i change the Oacb is not working. Same error.
                      can you tell me which Screw is to long or to small or send me a picture maybe?
                      Many many Thanks .
                      Himmelsbote from Germany
                      • Downunder
                        • Aug 2007
                        • 174
                        Re: BIZHUB 501
                        Usually jams in the registration relate to the two clutches in the ADU section. Probably clogged up with grease.
                        • mjunkaged
                          • 383
                          Re: BIZHUB 501
                          I tried that link last week and it says it's gone...do you still have the image? I could sure use it now and for further troubleshooting....they're hard to find just poking around with a magnifying glass!
                          • Synthohol
                            Certified Konica Expert
                            • 5824
                            Re: BIZHUB 501
                            6 year resurrection! nice!
                              Re: BIZHUB 501
                              A link 6 years old doesn't werk? Imagine that!!!!
                              DEAD FUCKING THREAD!!!
                              START your own new thread ..stating everything you have tried and/or replaced.
                              WE consider anything over 2 years from last comment a DEAD THREAD!!
