Hello all!
I know that I am not the only one who isn't completely satisfied with the duplex alignment on these machines.
I found out that "Side 2 Lens Adjustment" must be switched on for the "Both Sides" chart adjustment to work in duplex mode. The chart with "cut marks" on all four corners.
It's hidden under the Machine Admin, Common Setting menu. Switching it on has improved the alignment from front to back considerably.
It is claimed to reduce productivity, but I couldn't sense any loss in print speed.
