Hi,
We are having an image quality issue on our KM6501 (branded as OCECS665). I've included a PNG Image of what the defect looks like. It is a line that appears on 17 x 11" or larger stock, the heavier the stock, the more pronounced it is. The line almost looks like a stutter in the fuser, but it isn't. The defect is most pronounced in black. The defect is especially noticable in darker images and photos that have a high black component. However, if you print black only -- solid 100% it is fine. Only noticable in halftones and only in Black. Cyan, Magenta and Yellow do not have this defect.
Tried replacing drums, wires, fuser, trans. belt even the dev housing for black.
Hope someone has come across this, and found a solution.
