Bizhub 600 wont behave
  • Kmdurrin
    Copy/Print/Network Tech
    • Dec 2008
    • 132
    We've had a bizhub 600 in our shop for the last couple of weeks that simply doesnt want to be fixed. The first set of copies or prints done after the initial warm-up in the morning always have an extra little dusting of toner on the back of the page (back right edge only, very light, but its always there). Once the machine has run about 100 prints the mark goes away. So far we've replaced the drum, developer, burned a pm kit, replaced the dev unit, replaced the ICB, replaced the NVRAM, checked every ground, modded the drum and dev unit for better grounds, replaced the charge components, checked and re-checked the LD1 and LD2 adjustments, and replaced the HV board. We've been through every tech bulletin (dipswitch settings, mag angel, etc...), had multiple KMBS tech support sessions, and the damn machine continues to do this. Looking for any other ideas as to what might be causing this problem. Anyone seen anything like this before?
    Parts: Its what your copier craves!
  • SmellsHot
    Head Tech
    • 512
    Did you adjust transfer voltage? Also I would replace the T&s unit. The machine is pulling down too much toner.....
    Everyone has the right to be stupid. Some people just abuse this privelage more than others
    • pepper38_cnd
      Field Service Manager
      • Aug 2005
      • 1075
      Check and see if you tell it to exit face up, do you still get the dirty corner on the back side? If not you have some dev or toner in the duplex assembly.
      Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
      Now into Ip TV KODI Boxes
      • Kmdurrin
        • Dec 2008
        • 132
        We've replaced the T/S unit, and the problem continued. Toner looks like its spilling from the back 1/4 of the dev unit (back of the machine). We tried a different dev unit, but the spilling will start again after about 100 prints.
        • BIG PAPA
          Da Boss
          • 234
          Have you checked the dip sw settings for lowering TCR? Do you run Cart set before runnnig the rest of Drum Pec adj? Had a DSM Suggest this, it helps build the charge on the dev to get a more accurate reading during adjustments. Also dumb question are you using OEM parts?
          sigpic
          • Kmdurrin
            • Dec 2008
            • 132
            All dip switch settings have been assigned to their correct values, per KMBS tech support. All drum adjustments have been run in sequence, also per KMBS tech support. All parts used are OEM (I'm a KMBS dealer). Here is a picture of what the toner marks look like, and I'll upload a pic of the dev unit as soon as we pull it out (again).
            These were the first copies we ran this morning after cleaning the entire inside of the machine last night. The lines you see on the sides of the page will go away after running a bunch of prints, but they will come back even darker if the machine is shut down for a while and then re-started. As I mentioned before: The dev unit looks like its spilling off of the mag roller on the back 1/4 of the unit, but we ruled out the dev unit when we swapped one in from a BH601 in our shop and the problem started with that unit too. The 601 showed no spilling with either dev unit installed... only our problem child 600.
            • BIG PAPA
              Da Boss
              • 234
              As you are a KMBS dealer, the statement per Tech supprt doesnt carry alot of weight. LOL. After the copier sits, can you do an inspection and visably see where the lead edge would be coming into contact with the excess toner? Have you tried increasing the sep voltage to try to keep the lead edge lower as it passes under the drum?
              sigpic
              • SmellsHot
                Head Tech
                • 512
                When I've experienced similar problems like this I change the following dipsw's
                23-2-1 23-3-1 5-0-1 5-1-1
                After changing the DIPSW's run roughly 250 skyshots.....see if this helps.....
                tech support isn't much help unless they have the machine in front of them....
                • Albonline
                  • Sep 2008
                  • 1144
                  This has worked for me . but just a fyi most mid range konicas display this symtom.
                  • Kmdurrin
                    • Dec 2008
                    • 132
                    SmellsHot and BIG PAPA - Spot on about KMBS tech support.
                    Anyway - Just got done re-checking all the dipswitch settings and running a bunch of copies through. Everything looks pretty good right now... no dusting on the drum or mess inside the machine. Guess we'll have to wait for a bit until the machine cools down and try it again.
                    • SmellsHot
                      Head Tech
                      • 512
                      If it still does it.....try and stop the copy right below the drum section and see if you see the marks....
                      I've seen fuser cleaning webs do weird things and cause build up on fusing rollers causing somewhat similar problems like this...
                      Hope this fixes it!!!
                      • aleksander
                        • 378
                        replace the filter near developer unit or ozone filter. It may be help you.
                        • Kmdurrin
                          • Dec 2008
                          • 132
                          Came in this morning to more dirty copies! Here is the dev unit after the first run of prints today.
                          All the voltage settings are set to factory at this point. Any ideas what might be causing the toner dump on the edges? We just cant seem to figure this machine out. As I mentioned before - we swapped out a new dev unit from a BH601 in our shop, and it started to do the same thing after about 100 prints.
                          • mrwho
                            Major Asshole!
                            • 4299
                            Did you modify the dev unit's bias pin for better contact?
                            Mascan42
                            Ibid
                            • Kmdurrin
                              • Dec 2008
                              • 132
                              Both the dev unit and the drum have ground mods installed.
