Konica 7255 Drum Wrap
  • Bizhub
    • 147
    Hi All
    We have a 7255 that keeps wrapping paper around the drum. We have done the firmware, pickers, separation voltages AC and DC, set the drum voltage, checked the drum earth and stopped the wrap. Now we keep getting intermittant pale side 2 copies and if we re-adjust the separation voltages the drum wrap starts all over again.
    K-M say it's damp paper but the 7272 next to it is working fine and has never had this problem
    Any ideas?
    Regards
  • Luther
    • May 2006
    • 682
    Have you replaced the entire transfer/seperator assembly? I would try replacing it you may have a voltage leak from the blocks
    • Bizhub
      • 147
      Hi
      Thanks for your reply, we have changed the transfer corona with no effect. To date the machine has had dev, drum + voltage set to 744vdc, new transfer assy + voltages adjusted loads of times, new firmware + paper decks set to recycle, user, thick, thin etc we have replaced the drum pickers, picker solenoid, drum earth checked need I say more.
      What we find is that the paper A4C is flat on single sided, but on side two the paper rides up and hits the drum. A4R on both sides are flat, we would like to blame the paper but the 7272 next to it does suffer with side two riding up but it's never high enough to catch and jam.
      We have even tried raising the height of the separation wire to improve the separation and stop the wrapping problem, but to no avail.
      K-M have run out of ideas so its over to you guys
      • CMB
        KonicaMinolta Tech.
        • Mar 2005
        • 458
        try different paper? run it a differnt direction-if possible.
        • Luther
          • May 2006
          • 682
          If I'm not mistaken when the transport deck is installed it couples in the back to a suction fan for the aid in seperation,this is all from memory but thats why there are holes in the conveyance belts,check the fan operation, also heavy curl could be a bad lower pressure roller, just a couple of suggestions,good luck
          • ebm
            • Apr 2007
            • 183
            How about the "decurler" roller in the fixing unit?
            • Luther
              • May 2006
              • 682
              Could be, thats considered a consumable item, i would change it
              • TonerMonkey
                • Jun 2005
                • 71
                You may find there is a firmware release to couteract this problem - version 16 control board if memory serves right.
                • d7guitar
                  • Jan 2007
                  • 54
                  I feel your pain
                  We see this on 920's 750's and 600's. Not all them exhibit this problem???? Curious, did this start after a PM??? We have had excellent luck replacing the transfer wire with a non-KMBS wire. Order a spool of 70 micron wire, best they have, thicker gold plating. Before we found this (what appears to be) remedy, we were having some success (about 50k to 100k between calls) by moving both the transfer and the sep in the same direction +- by no more than thirty. That is only temporary and the CQ is affected. The wires we have been using for approx two months and have been VERY successful.
                  After all is said and done, More is said than done.
                  • Rudi
                    • Jun 2007
                    • 251
                    Try this
                    Hi there , try setting your drum voltage lower i.o.w from 744 to say maybe 700 or lower if you can then set your bias voltage (it is normally under high voltage adjustment) to about 100 or lower depending on how low you take the drum voltage in order to avoid background.i Have not done it myself but i think it is worth trying.
                    • Bizhub
                      • 147
                      D7Guitar
                      Sounds like you might have something there !
                      Where do you get you 70micron wire from ?
                      We also found that the engineer did not check the soleniod, It was seized !
                      We cleaned it out and the problem has reduced but still does it on Mondays after the week-ends. The customer now takes the paper out of the machine on fridays and puts into the DI3510 and then loads a fresh pack on mondays into the 7255 and it works a lot better.
                      KM can't help so I will try anything.
                      Shame the salesman can't upgrade it.
                      • AusiTech
                        Originally posted by Bizhub
                        Hi All
                        Any ideas?
                        Regards
                        If you still have problems let me know, I'm sure i have the fix. little long winded though.
                        • PeterG
                          • Jul 2008
                          • 177
                          4 year old thread, but I have this exact problem. Has anyone been able to come up with a definitive answer to this problem? No matter how long winded.
                          • Downunder
                            • Aug 2007
                            • 174
                            Whats the mileage on the copier. How much gap is there between the drum pawls and the drum. Is the drum wrap happening from all trays.
                            DC transfer seperation should not be more than 130 max, preferably 120-125. If there is a bit of paper slippage this could mean that the pawls are coming in too early, or paper coming too late, hence the question does it happen from all A4 trays. A4R and A3 don't count in this equation.
                            If the drum pawls have a big gap (more than say 3mil) pack something (we use a bit of velcro (shaved) with tape on between the solonoid and the solonoid resting spot (best to look at the operation of the solonoid and this packing statement will be a bit more obvious.
                            Also best to try and put most settings back to factory settings if you can.
                            Tonermonkey was right there was a firmware upgrade -- its purpose was to have the pawls stay activated a bit longer.
                            The decurl roller and its bearings probably need replacing.
                            Hope this helps . . . l
                            • PeterG
                              • Jul 2008
                              • 177
                              Thanks Downunder.
                              The copier has about 3 mil on it. The drum wrap is happening from all trays. We do a changeover fuser service and the same problem exists after a fuser change over.
                              I have watched the paper, maybe 40 or 50 sheets may pass ok, then one will stick.
                              We have had ferocious humidity down here lately, which I suspect is the root cause of the problem. Unfortunately the customer does't accept this as a reasonable excuse.
