hp 9850...c500?
  • copierlady
    • 338
    hp 9850...c500?
    working on HP 9850 I think is same as KM c500 has sc 30-10... Help?
  • Albonline
    • Sep 2008
    • 1153
    How to clear fuser abnormality codes (F34-xx, F35-xx, F36-xx).
    Description:
    Solution:
    To reset a fuser abnormality code, perform the following:
    1. Access the 25 mode (hold down the 2 and 5 keys at power up) or turn the main switch ON and wait for the Ready to Copy message. Hold the P button down until the message Enter 4-digit Password To Change is displayed.
    Note: The button must be held down for about 5 seconds before the message is displayed.
    2. Enter the password 9272 and press the Start Print button.
    3. Press [1: Software SW setting] on the touchscreen.
    4. Press the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
    5. Select the bit number of switch 1, using the right up-arrow, 03-1 will be displayed.
    6. Press the [OFF (0)] key, which is displayed on the touchscreen.
    7. Power the machine OFF/ON to exit the 25 mode or press RETURN, MODE CHANGE and then BASIC SCREEN to return to normal operation.
    that code does not show up inany of my c500 service manuals
    • Albonline
      • Sep 2008
      • 1153
      ignore my last cheese headed reply
      ADU conveyance drive board
      communication abnormality
      Conveyance drive board
      (CVDB)
      Printer control board (PRCB)
      • copierlady
        • 338
        Thanks for your help.
