c3102 just stops mid stream
  • digicor
    • 1153
    I have a c3102 that just plain stops in the middle of a job, the job is 14 pages and 30 copies of this form.
    does not doi it on small 1 page 2 page ect jobs. I have replaced the fuser, fuser motor, main motor's,feed tires, feed tire one way clutches, ect.is there something else hesating up and stopping the machine?could the transfer cause this?im outta ideas....
  • BIG PAPA
    Da Boss
    • 234
    What does the display show? Any error? What options are installed? Finisher, Fax? Remove options and test to narrow it down.
    sigpic
    • digicor
      • 1153
      thanks for the answer, but, there is no fax or finisher, however there is the print controller on the back these all come with, but its doing it when copying, not print, i going to ask the client to print the job instead of copying it tomorow just to c if there is any diff.
      thanks
      • digicor
        • 1153
        also there is no code out.
        • bkcusp
          • 5
          Re: c3102 just stops mid stream
          faulty or dirty exit pressure sensor or broken actuator. clean or replace sensore if problem still persist replace all exit gears.
