Dialta 2011
+ More Options
Posts
  • hussain
    • 28
    [Jamming] Dialta 2011
    Hello Friends,
    I have two 2 machines ( di 2011 ) in my workshop that I couldn't repair yet. both machines have same problem.
    Problem ; When I give multiple copies the first 2 pages will come and the 3rd sheet tip can see in the paper exit section and 4th sheet is just taken up AND than stuck. after massage displays ( says 1st right side door is open / Paper jamming ) . I noticed the 3rd sheet is always blank, no image.
    I checked paper path for any obstruction and the path is ok.
    If you have faced similar problem please let me know how to correct.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    I have not heard of a 2011. But if the machine says the door is open, then I would use the I/O check and maybe the door switch needs to be adjusted.
    • lordqpa
      • Oct 2008
      • 22
      Two ways:
      1) Replace take up roller
      2) High voltage leakage (damage drum or/and mag. roller seal - drive side)
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        You can also have the registration clutch going bad.
        • deep
          • Jun 2008
          • 208
          If the location of the machine is with relatively high humidity, I would blow dry the High Voltage related components.
          Also check the drum charge and transfer for any high voltage leakage.
          Kenny
