Bizhub C250 double imaging
  • Timothy
    • Mar 2010
    • 14
    I have a Bizhub C250 that has been doulble imaging down the page and it does it in all colors. I replaced the fuser assembly and that worked for two days and now it is back and worse than before. I increadsed the fuser temp by 5 for both the hot and pressure roller and it still has not made a difference. I am kind of at a loss at this one. I have inspected the transfer belt and all of the drums and do not see a problem.
    Any help out there?
  • Stirton.M
    All things Konica Minolta
    • Oct 2009
    • 1804
    Do you have the fuser in envelope mode?
    Check the green tabs on the front and rear sides, make sure they are up and not down.
    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
    ---Groucho Marx
    Please do not PM me for questions related to Konica Minolta hardware.
    I will not answer requests or questions there.
    Please ask in the KM forum for the benefit of others to see the question and give their input.
    • PeterG
      • Jul 2008
      • 177
      Someone is going to be embarrassed over that one.
      • copytechman
        • Nov 2008
        • 931
        Also check your 2nd transfer roller. I've seen the newer series (c203-353) have those fail and produce symptoms that look pretty much the same as a failed fuser. Led me down the garden path too. Had 1 case of it with a c250 iirc.
        Regards!
        A.
        • Timothy
          • Mar 2010
          • 14
          Ok I am embarrased the fuser was in envelope mode and I will admit that I missed that in my haste to repair this machine. The original problem was not fusing on one side and it was not in envelope mode so I didn't even look at that. Thanks for your help.
          • PeterG
            • Jul 2008
            • 177
            I doubt their is a single one of us that hasn't fallen for that one Timothy.
            • Stirton.M
              • Oct 2009
              • 1804
              There are days we are all sleeping at the wheel..... heh
              :P
              ---Groucho Marx
