bizhub C200 Sitze detect Section Sensor problem.. Help please
  • freixi
    • May 2009
    • 53
    Hello everybody,
    I have a problem with my bizhub c200 in the Sitze detect section.
    The sensor 12 or (20) PN. A02FPP0M00 is giving me connectivity without a sheet of A3 above. Not for the scanning documents that detects a sheet A3. I have replace the sensor and see the same thing happens. The service menue can I test the sensor and it says this on (1) sen leaf, with leaf switches to off (0) then it is working to reverse. I do not know what to do .. someone can give me a hand?
    Thank you very much
    Freixi
  • pepper38_cnd
    Field Service Manager
    • Aug 2005
    • 1075
    Make sure the little leaver that tells the sensors when to work isn't stuck down. The lamp should light every time you close the DF.
    Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
    Now into Ip TV KODI Boxes
    • freixi
      • May 2009
      • 53
      Thanks for the reply, the lamp turns on and off when I open the ADF. The sensor is new. I do not know why it is on paper without methodological role in and when it shuts down. You can check this in test scanner in Service Mode.
      • emujo
        • Jun 2009
        • 3009
        Not sure on the C200, but C353 C550 series use the CCD to determine paper width from scans off the glass. I've had 2 or 3 bad CCD cause this problem. Emujo
        • freixi
          • May 2009
          • 53
          I took the service call report and have these errors:
          6102: Drivesyst. Homesensor (1)
          6751: CCD IC amp Gain Adjust (2)
          6401: Scanner Ohter Trouble (1)
          P28 IDC sensor rear (1)
          ADF feed Jam (2)
          ADF transport Jam (4)
          Did they speak of but CCD was spoiled he is not took copies.
          Did not know whether the sensor to be activated without ten leaf?
          • pepper38_cnd
            • Aug 2005
            • 1075
            Since you have had 2 CCD gain adjustment errors. Check and make sure all mirrors, the lamp it self and the lense are clean, also the strip that is read at start up I'm not sure where it is on that machine if it is attached to the glass or the bottom of the scale plate.
            • freixi
              • May 2009
              • 53
              Thanks for the reply, tomorrow morning I will check this and tell then something. once again thanks.
              • emujo
                • Jun 2009
                • 3009
                You see CCD errors, replace the CCD!
                • freixi
                  • May 2009
                  • 53
                  hi to all.
                  It is not the CCD. I even had the main motherboard to install here and then I noticed that the hinge, the left side is broken and not report the ADF rests. This comb pure light and simulates an A3, after the repair of the hinges of the errors is gone and it works fine.
                  I thank you all for the nice support added.
                  PS: I wish to make pictures because my english is not good.
                  Freixi
                  • Stirton.M
                    All things Konica Minolta
                    • Oct 2009
                    • 1804
                    Originally posted by freixi
                    hi to all.
                    Freixi
                    "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
                    ---Groucho Marx
                    Please do not PM me for questions related to Konica Minolta hardware.
                    I will not answer requests or questions there.
                    Please ask in the KM forum for the benefit of others to see the question and give their input.
