BH PRO C6500 Card Stock CQ Problem. HELP
  • ineo+6501
    • Mar 2010
    • 262
    [CQ] BH PRO C6500 Card Stock CQ Problem. HELP
    Hi Guys,
    I have a C6500 which is misbehaving on 350gsm SRA3 stock.
    See the attached image. Looks like the sheet is stalling somewhere.
    Changed decurling rollers, fixing exit rollers and no change.
    There are no visible burrs or any damage on the fuser exit passage.
    I am aware that the machine is only rated to 300gsm but the customer has had the same stock through another C6500 with no problems. And I have had it through several 6501's with excellent results.
    The 6500 in question is on 2.7mil.
    Any pointers or workarounds would be gratefully received.
    Cheers
  • RRodgers
    • Jun 2009
    • 1947
    Originally posted by ineo+6501
    Hi Guys,
    Cheers
    I can't see the image on my phone, but maybe try the belt line speed adjusment.
    • albasoul06
      The Bypass Tray and Tray 5 in the PFU are the only trays that support 257gsm to 300gsm.
      • mrwho
        Major Asshole!
        • 4299
        It's been a long time since I last serviced one of those, but I once had a problem with a smudge in that position and it could be solved - or at least mitigated - through the process adjustment on the tray properties. I don't recall which one exactly, but try for a while on each adjustment with some variation upwards and downwards until you see some differences on the printout.
        Mascan42
        Ibid
        • ineo+6501
          • Mar 2010
          • 262
          Thanks for the thoughts guys. And I can confirm that the stock is being fed from tray 5 and on 257-300gsm setting. It is coated-GL SRA3.
          I'm heading over to the customer now and I'll have a crack at your suggestions.
          • HORSE
            • Mar 2008
            • 185
            Ha thats an easy one
            350 gsm is outside the spec of the machine end of story.
            But I suspect that stock is long grain, if you ran 350 gsm short grain it will probably improve it.
            Better still if you really require 350 it should be mondi .... if you use crap long grain stock that your average backstreet printer buy then you are going get crap results like that. Its an absolute non starter.
            Laughing......
            • Stirton.M
              All things Konica Minolta
              • Oct 2009
              • 1804
              you can also try to adjust the timing settings as well...might be something simple as that...
              "Many years ago I chased a woman for almost two years, only to discover that her tastes were exactly like mine: we both were crazy about girls."
              ---Groucho Marx
              Please do not PM me for questions related to Konica Minolta hardware.
              I will not answer requests or questions there.
              Please ask in the KM forum for the benefit of others to see the question and give their input.
              • anothertech
                • 1763
                Make sure the machine is sending out the copies faceup.
                • ineo+6501
                  • Mar 2010
                  • 262
                  Thanks guys.
                  HORSE, I have already informed the customer that 350 is beyond spec, but he has a valid point that the same stock has been through 4 other 6500/01's without problems.
                  Stirton, is there a way to adjust the timing for just 257-300 setting? I don't want to cock-up the timing for all other settings?
                  Anothertech, the machine does not allow face down on 257-300.
                  • HORSE
                    • Mar 2008
                    • 185
                    Thanks guys.
                    Its not valid at all, last time I was in Japan BT said they will only support recommended stocks or stocks that are within Spec.
                    I would say that its a more valid point that all those other machines that run this stock without problem could at any stage in the future do the same thing, who knows...... but my 11th Commandment is "if it ain't broken, don't fix it!!"
                    Laughing......
                    • Stirton.M
                      • Oct 2009
                      • 1804
                      I agree with Horse on that particular point....
                      And for your customer, print and give them one of these....
                      C6500STAGuidev3_MediaGuide.pdf
                      If they do not like the response, too bad. I will never make the machine do what it was not meant to do.
                      ---Groucho Marx
                      • HORSE
                        • Mar 2008
                        • 185
                        Sorry thats my 12th Commandment.
                        11th Commandment...."cover thy Ass"
                        Laughing......
                        • beetle73
                          • Dec 2010
                          • 44
                          Try using short grain paper instead of long grain.
                          • PoonKing5000
                            • Jun 2008
                            • 111
                            Has there been a resolution to this problem? I have a machine that is displaying the same issue.
                            Andy
                            • CT Copier Repair
                              • Mar 2010
                              • 304
                              Yea
                              use recommended stock
                              i had a company that used RS232 comm lines for data transfer ( i was corporate tech support)
                              new machine better com specs but they would not communicate
                              turns out the length spec of 50 ft was not being followed got the same response they used to work
                              upon investigation they were spending about 10 man hours a week to get the machines to communicate garbled data dropped connections
                              called manufacturers engineering deptartment in
                              they took one look at the lenght of the data lines
                              said out of spec and walked out
                              charged the branch 35,000 for travel and expenses and it was done
                              just becaue it worked doesn't mean that it will continue or ever even has
                              have you run these jobs on the supposedly working 6500's ever seen it work
                              oir did the customer tell you it worked
                              start there and then repeat after me Stock is out of spec
