Error code C2557
  • RAKOTOBE Oliva
    [Error Code] Error code C2557
    With my Bizhub 250, I got an error code C2557.
    Can you help me to fix this error
  • ck1
    • 485
    check you developer lifespan ...
    • Stirton.M
      All things Konica Minolta
      • Oct 2009
      • 1804
      The code references an abnormal low toner density in the black IU.
      Check the toner bottle to ensure that it is feeding toner into the sub hopper unit under the bottle. Sometimes users will insert the bottle incorrectly and not lock it properly in place...the lever on the front of the toner hopper for that bottle is moved down to the left to remove and insert the bottle. When moved to the upper position, it both locks the bottle in place and opens a cover on the bottom of the bottle.
      It is possible the toner hopper itself is not functioning as well. Either the motor drive is not working, that is, broken, or there is a problem with the printer control board that it is connected to. This is a rare problem and not very likely.
      Also, it is possible the image unit itself is defective...the sensor could be at fault...or its not pushed in correctly to make an electrical connection.
      ---Groucho Marx
      • minimerlin
        • 851
        Try searching the forum and you will find the code usually happens if a drum or dev count has been reset without actually replacement. You also have to do the clearance of the counters before closing the rh door.
        Always search the forum before asking for assistance, as often the fix has been posted before.
        Please do not PM me without asking first.
        • emujo
          • Jun 2009
          • 3009
          This code will occur if you relplace the drum unit w/o replacing the developer. Emujo
          • Hansoon
            • Sep 2007
            • 3383
            http://www.copytechnet.com/forums/ko...hub-250-a.html
            and:
            http://www.copytechnet.com/forums/ko...ode-c2557.html
            there are many more when you use the search option.
            Hans
            โ€œSent from my Intel 80286 using MS-DOS 2.0โ€
            • Stirton.M
              • Oct 2009
              • 1804
              Ooops...disregard my last...I somehow thought the machine was a C250....different beast all together.
              ---Groucho Marx
              • fixthecopier
                ALIEN OVERLORD
                • 4713
                This is another case of all the techs guessing because the poster did not think any extra info was needed, like a meter count and when , if ever the drum was changed. If you are a user, call a tech.
                • Hansoon
                  • Sep 2007
                  • 3383
                  From an end user or an untrained tech in a 3rd world country this would be understandable and forgivable but you're right FixTheCopier, some of our "professional" colleagues...........
                  Hans
                  • NEOTECH
                    • Dec 2010
                    • 69
                    ATDC PROBLEM
                    Originally posted by rakotobe oliva
                    with my bizhub 250, i got an error code c2557.
                    dear u have a problem in your drum/developer unit replaced or developer
                    replaced only and agin celibrait devloper this is only atdc sansor .
                    • montana
                      • Aug 2008
                      • 392
                      hi..this error code related to the ATDC sensor..may you should make ATDC adjustment in the service mode...or if you replaced the developer with incorrect one..this machine working with dv310 type
                      i hope this help....happy new year..
                      • fixthecopier
                        ALIEN OVERLORD
                        • 4713
                        Hans
                        You are correct. Same people would call a car repair center and say "My car runs bad, what could it be."
                        • stefanv
                          • May 2010
                          • 13
                          Try to set atdc gain under tech rep choice to 120
                          Do not clear IC or PC life + will cause 2557
                          Set Mode 418 bit 3 to (0)
                          • kenny@kmfs.co.za
                            this code means K TCR sensor error (toner carrier ratio), so the imm.unit has reached its end or the toner is not enough , meaning the ratio between toner and carrier or developer in the imm. unit is not in spec . if toner is stil enough then change imm.unit . you can add toner in service mode and see what it does.
                            • copierdude1
                              • Jan 2011
                              • 12
                              Could be a lot of things. Are you running after market toner? If you reset the I.U. with out an actual replacment, did you check you toner levels first? Is the toner path clogged? (seen it with after market junk)
