c6500 paper crimp in the middle of 11x17
  • jzheld
    • Sep 2010
    • 162
    [CQ] c6500 paper crimp in the middle of 11x17
    Doesn't happend all the time but in 20% it is like that, do it only to 20-28lb 11x17, checked all rollers, seems to be good. Can anybody help me. Thank you. John
    • 23009
    Re: c6500 paper crimp in the middle of 11x17
    Looks like moist paper to me. Have you tried fresh paper?
    The longer papers are more susceptible to wrinkling, as is duplexed prints. =^..^=
    • jzheld
      • Sep 2010
      • 162
      Tried fresh paper, now it's doing it for both single and double sided, almost all the time
        • 23009
        Next thing to look at is the fuser unit.
        • Ianizer
          • Jul 2011
          • 380
          Fuser issue. Aged rollers out of round... Either due to lots of copies, or not enough copies. Nip band width out of tweak.
          I'm absolutely positive it's either that or something else.
          Or crummy paper.
          Information. I crave information. What's machine age, copy count, paper type, customary storage, environment, usage type, FW version, PM levels, and anything else you'd like to provide.
          -I
          My name Peggy.
          You got problem?
          • empiru
            • Feb 2011
            • 229
            Had this one on 2 C6500s; in my case (s) the problems were totally different from one another but since I think you're an end user, I'd suggest you call a tech and pay him to solve your problem. Good luck!
            PS: in my cases, the fusing units were fine - no problems there.
            I don't help end-users. Hate me, give me bad reputation, I don't give a rat's a**. Pay a tehnician to solve your problem! We have to live too! What do you do when something hurts? Do you go to a doctor, or do you search it on google/ forums?
            • maccenterpc
              • Sep 2011
              • 40
              Note paper output is set to face up or down. Try to arrange face-up.
              Note whether the paper type is set correctly.
              If the above are ok, check the roller bearings top and bottom of the fuser unit.
              Maccenter
              • Ianizer
                • Jul 2011
                • 380
                Innnnterestink...
                Ditto the user on the end.
                Jam it! No guts, no glory!
                -I
                My name Peggy.
                You got problem?
                • RRodgers
                  • Jun 2009
                  • 1947
                  Yep, check the fuser entrance guide as well as the exit guide plate. I've had wrinkles due to one of the screws that hold the springs on a C500 work loose. Weird to see, but it did happen and it was wrinkling.
                  Good luck and I'm sure you'll find it.
